Introducing The New Crucial M550 SSD
MacClipper
If you dislike the usual forum style of interuppted posting, you can also read this sharing in its entirety on a single page here
Source
Official Page
Crucial.com
Production Status
Seems the 2.5" and mSATA are already in production while the M2 form factor is still pending...
Client SSD - Micron Technology, Inc.
Preview Sample
Came as a retail 2.5" package, proudly MIS ie. Made In Singapore!
Unboxing
Just the 7mm SSD itself in anti-static plastic and a simple plastic spacer to pad up to 9mm if need be
Do note that the fragile warranty void metallic foil sticker cos it tears very easily if manipulated in any way...
MacClipper
Dissassembly
Tool needed - Philips screwdriver ie. + tip
Components Disclosed
Seems all inhouse Micron components from the RAM cache to the MLC NAND flash chips themselves save for the debuting Marvell SATA3 controller.
Micron on types of NAND flash chips...
MacClipper
Test Setup
★ Z87M OC Formula | i5-4670K@4.5GHz | NiCu HK 3.0-GTX360 | R9 290 | Thermaltake Smart SE 630W ★
Crystal Disk Info
Crystal Disk Mark
AS SSD Bench
ATTO Disk Benchmark
Too New!
Yet unlisted in Crucial support page... that's how new it is.
The Crucial M4 and subsequently the M500 have been longtime favourites for their incredible cost performance and stability, will the M550 star shine as brightly too?
Ark Law
Seems all inhouse Micron components from the debuting SATA3 controller to the RAM cache and MLC NAND flash chips themselves.
Since when was Marvell subsidiary/part of Micron? :p
wwenze
TLC... 3 bits per cell so only 50% more bits than MLC but now the levels have to be twice as precise... diminishing returns...
At least SLC to MLC is double capacity
juna
Is this Crucial 512GB M550 M.2 SSD SATA III 6Gb/s available in Singapore??
