IF i really get the monsta i must push pull coz of its thickness right?
no hard and fast rule that you must.... usually a push or pull will do - if p/p then its thickness is really
anyway MWTS all my monsta rad since i going AMS... interested can PM me...
@Op_Valkyrie, what filters are those???
just buy led strip =D
haha see how ba....considering adding another 120mm at the rear....so rad outside case fan inside...
You gonna run tubings via the rear top? Wun it have conflicts for space wif top mounted rad?
Hey guys my current plan. Alot frends ask me take full kit better....my rad and res still not cfm...coz i got no plans to do lighting....i wan red lights but my gpu blue light de...anybody know how it will look if full case red lighting then gpu there blue
For your bitspower fittings, can try email to bitspower taiwan directly, and see how much they charge you. Coz without a visual look of your parts mounted, hard to see if fittings will work or not. Granted that all straight fittings will work, but tubing may be messy.
oh great thanks. ya i noe will be messy but since its just a cpu loop for now and also my first time...i was thinking of simple and easy to learn...then later on start adding right angles and swivel fittings....also wanna get the quick detach drainage fitting like dam good
Koolance QD3 ah?
