MyRepublic fibre - Part 4
Binaries
Wow.. some service I got trying to call MR customer service.
"All circuit are busy now... Good bye.." and auto hangs up the phone..
Till now no one calls me to tell me whats the follow up action in this case of a failed installation.
Maybe this is the sign to tell me to look elsewhere since I am out of contract already.
You made me chuckle when you reminded me of the post you made to mine regarding to the level of customer service and how MR couldn't scale well to the amount of consumers it got right now. Chill, did you not expect it ? :) Hopefully we'll tide it over and get the upgrade as promised but one thing I noticed.. follow up is a hard promise to come from MR, most of the time it will not be delivered till you pester them to no end. Hah.
henrylim1972
Kindly chec kthe firmware the upload is correct. the download is wrong, which should't be happen . check direct connection to ONT as well.
I have upgraded the firmware already. At a loss now. Everytime I measure the speed of ONT, it's ok (in 800). But once I start using it , it simply tapers.
I suggest new subsubscribers test it a couple of times before signing off on the contract. I suspect I have a faulty ONT set.
misato
I should change job to be a fortune teller (too extreme.. business consultant maybe).. all my predictions are coming true and myself being caught in it as one of those "victim". As it was said before.. when it comes to this, when the ship is sinking.. don't want to jump also cannot especially when everything else outside the ship looks better (including sampang).
cyberet
which version are you using?
try Version 3.0.0.4.374.583
mashpotato120
MR your engineer is 2hrs late, can you assist to check where and if he is coming.
Want to go out and get lunch but scared the engineer appear during then.
Finally the MR engineer is here and got my 1gb up and running.
Will be posting some sample results VS my 150Gamer this morning.
PS: Would really be nice if MR support can liase with the onsite engineer and update the customer at interval . Waited 8hrs today for nothing.
PPS : Not pushing the blame to the on-site team, as judging from their work schedule, they are been overloaded as well.
Johnnny
Apologies on the wait mash, we'll let them know to reach out to customers better. Looking forward to seeing your results!
mashpotato120
This is just a simple comparison between the new 1gb gamer VS 150mb gamer.
I dont really view china content so i cant really test that out.
Also i dont view twitch.tv as well, so i wont know what the standard previously, however as a simple test i tried Diablo ROS stream (source quality), video loaded instantly, no buffer through out the 10mins. Would have taken a screenshot, but that dont prove much.
Test Bed :
Desktop i7 / ssd / Killer NIC
Laptop i5 / ssd / Intel NIC
Speedtest results. If this matters to you.
WOW - Oceanic server , testing differences between killer / Intel NIC
Since there is not much different, the remaining results are tested on the desktop(killer NIC) only.
WOW - US server .
mashpotato120
More tests, where higher speed matters.
Download Ubuntu from NUS server. Somehow 1GB gamer is slower. The 3rd results is download from AMD website, graphic driver file size is not big enough to show a fair result.
Download more "Ubuntu" from different mirror sources. Im very impressed with the result. Just hope they can maintain it.
From Rapidgator.
From Ryushare.
Do let me know if you want me to test any specific link / tracert.
Cheers MR
WindJammer
2.4Ghz
5Ghz
Even my Note 3 having only 50mbps on 2.4Ghz.
It is awfully wrong somewhere. Can MR provide help pls.
Using AC68U.
Acc: C8635
Just Me
2.4Ghz
5Ghz
Using AC68U.
Acc: C8635
To be fair, my iPad mini retina can only achieve ard 60down/50up and 160/150 on 2.4/5ghz respectively on my n66u.. So I think your note3 speeds are correct
zer0ne
From Rapidgator.
From Ryushare.
Cheers MR
Nice Ryushare speed.:eek:
qingtian
Installation for my MR 1Gbps is here in the morning.
Did a speed test via speedtest.myrepublic.com and was getting a reading as below.
**Speedtest was done directly on LAN connection via ONT Modem.
I had escalate the case to MR after calling multiple time in the noon. :s22:
MR support mention that they will need 3 days to rectify this issues.
Which I wasn't even advise is this related to hardware fault.
henrylim1972
It's definitely a hardware problem ... I have the same problem ... download speed is bad !!
tcyr123
is anyone facing random disconnections? My internet these few days has been randomly dropping for a few seconds before reconnecting, getting quite annoying.
CoolRock
I experiencing slowness even when surfing web. No download, no streaming, no torrenting. Contract up soon, thinking whether to change ISP anot.
