A fact to note before buying Plantronics bluetooth headsets
discoburg
whats the difference between the 2 models besides material used.
Get a Bluetrek Titanium or Carbon, sound and voice clarity much better imo.
tekster
Apologies to dig up this thread.
Im kinda interested in the Voyager Legend after going through the reviews.
Is this a good deal?
https://www.alldealsasia.com/daily-...etooth-headset-worlds-smartest-headset-courie
i can sell you identical stuff but it's still fake.
you want, u can take my set and try. play around with it.
i got voyager legend and voyager pro hd, both from china which i think both were fakes. if you were to ask me,i think the pro hd is better as it doesn't use proprietary charging like the voyager legend. pro hd uses microUSB charging which is quite universal these days with android phones.
the other note is, if u got a friend going to hk, u can get them to buy at the airport and bring back for you. i think it costs something like sgd120-130. i'm sure it's a guarantee original.
battery wise for both legend and pro hd, they last damn long. a 3-4 days 8hrs a day usage which i think is a very good deal.
the reason why i need a over-the-ear-hook type of headset is because my skin is oily. so those jam-in-your-ear type, it will pop out. this hook type stays on very well.
yunao1980
Anyone bought VOYAGER LEGEND from Qoo10 before? Is it advisable to buy from Amazon and not Qoo10 as i do see some scams in there and how safe is Amazon?
Pls advise
Kumsia
Badb0y07
Pls advise
Kumsia
I bought my unit from Qoo10, and until now it's still working perfectly. Don't know if it's a fake or not, but the gimmicky noise cancellation and everything is working fine.
Even if it's from Amazon, better hope it is not a faulty set, because you have to send it all the way back (IIRC), or you need to send to a local Plantronics support centre.
Well, That's the drawback of online shopping.
daewood
;) threadstarter thanks for the note, btw any amazon sites or links to recommend to get Plantronics Bluetooth headset?
jokerpoker81
i think if want wireless headphones, there are so many chiong or unknown (but original) brands on the market, such as the chiong Beats headphones i have. it is a chiong set, but wireless works great! i mean, seriously.
It is only if you want wireless + noise cancellation, then can only go for the original, better known brands.
I have old model, original Audio Technica ANC7b ( wired, noise cancelling ), but when ear cushions wear off, have to spend about $20? or is it $50? cant rem... to change new pair of ear cushions, and must go down all the way to their service centre, kind of troublesome...only about 1 year+ need to change liao.
seantan101
Hi, standard platronic wireless in ear headphone bought from challenger, warranty wise is 1 or 2 years? Thanks
Ed.YEO
哩件事教訓我地,哩個時代,廣告打得幾響,品牌話自家產品有幾撚勁。。。推高銷量,仲大過品牌嘅可靠性。
唔做死忠嘅品牌支持者,做明智消費者!
KlavierX
any of u guys have any advise, updates or service improvements?
For any brands or just Plantronics?
I feel like we should have stuff like replaceable headphone pads easily available in major audio stores rather than just the service center
Sent from My Pigu using GAGT
