Finally got time to post something after I got my purple set on fri evening.
After 3 days of usage, my review against my previous Z (white)
Good
1) Purple sibei chiooooo ah. My wife 1st look at it also comment swee, want to get also.
2) The screen sibei chiooo ah
3) The sound also much better
4) Camera confirm much better, took some pic, and tried some feature, chioooooooooooooo.
5) Battery life damn good loh. Didn't charge fully on 1st charge, although advise by singtel cso to charge 8 hrs. And it is damn lasting. At least can feel it is 2 to 3 times better than Z battery life
6) The small button for photo shooting is very smooth and easy to use. Very handy. No need to touch screen capture
7) Surprisingly Z2 does not heat up as much as Z do. Usually use abit of chrome and it will be damn hot at the back. I use for 1-2 hrs continuously also don't feel hot.
Bad
1) The screen insensitiveness, same as all your comments. Doing update now and hope it works well. Previous feel so when I tried demo set, and thought maybe result of demo kanna molest too much
2) Don't know what Sony thinking, give such a shitty ear piece. Z one is so much better!
3) My SD Card slot flap, when close, can feel that it didn't flush/align swee swee at the top. Can see abit protrude. ie flap sink too in. Anyone has this issue?
Really not much complain. Have been using Sony hp for long, and this is the most satisified model used
