sG_KYo
- Jan 27, 2004
as expected, a biased review from hwz
expected is actually an understatement.
u should compare side by side with a Samsung, HTC and Sony review and u will see.
ehh u quote wrg post/ reply wrg stuff?
any advise if i shld accept the exchange if only gt gaps?
what else need to check? apart from cosmetic n gaps...
paiseh for wrong quote. You want phone with imperfection meh. I won't want lol. Unless I drop it and scratch etc la.
the battery test and real world usage stats (from my colleague James) seemed to suggest that its bad ...
but as we all know, battery mileage varies according to usage patterns. James may be a heavy user, thats why the battery mileage was rated bad.
nonetheless, I shall update you guys by the end of the week on the usage stats including screen on-time.
ya lor. My Z2 from morning 9 until now still got 28 percent left.Maybe M8 and S5 last even longer.
Yours look right. Anyway, the link you use is wrong. use http://i58.tinypic.com/33wb4ad.jpg instead.
I also Chua sai after hearing the cost but he applied liao so llst. I forgot to ask him the SP cost as I also assuming it's around 20+.
Is it normal when the network bar drop to no signal when placed in the water?
may I know why?
do feedback to us which part(s) of the review you feel is/are unfair, and we shall try to see if things or testing can be done better.
we ain't pro-samsung. I've been very busy the past week. will give the Xperia Z2 a try soon (hopefully) and give you all some screenshots of the real world usage stats.
Of cos. Cellular frequency doesnt work in water. Its like how sound can't travel effectively in water...
how come my phone will change to ringing mode on instead of vibration during teh night ?
