z2 is not well suited for continuous usage. High temp will result in unnecessary drain.For light surfing on Internet, what Shld be a reasonable drop in battery %?
Mine seems to be dropping quit fast despite on stamina mode...
On side note, loving this phone, as to S3... Hahaha
I just received an update for z2. Anyone also have the same thing?
Same as samsung note 3 the slot is made for micro sim. If U use adapter it will damage the SIM slot.. For what i know samsung will not repair for free. Dont know Sony will anotDear folks, it has been agonising today. My brand new Sony Z2 SIM slot connector pins broke.
The SIM slot connector pins got caught in the SIM card adaptor that was used for my nano sim card. When I got a proper Micro SIM from M1 to replace, the adaptor refuse to dislodge from the Z2's SIM slot. After some time, the adaptor came out.
Then after slotting the proper Micro SIM, the phone refuse to detect SIM card. Using a torch to look into the Z2's SIM slot, i realised the connectors were broken.
The SIM slot connectors are just very thin copper pieces sticking out in the opposite direction towards the internals of the phone, and it can very easily get caught in those SIM card adaptors that available on the market.
Sony Service Centre personnel say that if the SIM slot connectors are broken, have to change the entire motherboard which will cost almost a new Sony Z2.
Feel it is very unfair cos of the lousy design of the SIM slot, we have to bear the consequences if the SIM connectors broke due to us using SIM card adaptors or even a frequent removal of SIM cards may result the connectors breaking.
Now awaiting Sony Singapore to reply what is their next course of action. I hope they can replace my Sony Z2's motherboard for free because of this design flaw in the SIM card slot connectors.
Magnetic cable nt bad.. from 6.03pm to 7.49pm, batt charged from 51% to 99%.... most probably, i will get another for office.
Just paid for another cable... This time, it was 30 cents cheaper....
New Xperia Z2 update (17.1.A.2.55) released; primarily bug-fix improvements [Update] | Xperia Blog
Just updated.. these are the improvements they said.
Hi,
can anyone help to verify this issue :
1. ensure that you set to save camera pictures in SD card.
2. take a picture using the camera.
3. go to Album and delete the picture just taken.
4. close Album and then go back in to verify it is deleted.
5. go to File Commander app to browse to the folder in your SD card that stores your camera pictures. eg. SD Card/DCIM/100ANDRO
--> you will see your deleted picture there!
6. now go back to Album and the picture reappear in there too!
I tried using QuickPic, even worse, no need to perform step 5, just kill QuickPic in the background, and then go in again will see the deleted picture.
Shouldn't be SD card problem, because I already format before and also I tried another SD Card also the same thing.
play game drain less?can sic link?my taobao loots still not here yet
there is a newer update to 2.55? or u all referring to the update that we get since last fri?
yar, noted the high temp, but previous batt didnt drain that fast when i using to play game n all. today i just surf hwz nia then batt drop 10% in 30min in stamina mode. kinda too fast?![]()
whereas your game not so "bright"
