- Aug 9, 2011
eh, my ST Fibre 200mbps only can get 20mbps le, how come ah?![]()
Some thing is really not right so just need to call 1688 to get support to go down to your home. It can be ONT or Router faulty. If you are using wireless then it will depend on your home layout, set up, how big is your home, router location and whether you have dual band router. For wireless really need a lot of knowledge and there are limitations to wi fi connection. To get ST dual band router you must sign up during major fair or during their promotion. For normal day when there is no promotion or no fair then must get 300Mbps to get dual band router. Always suggest signing up during major fair or promotion period or road show with promotion. Can always request for support staff to come down to do a check and change the ONT or Router. Even for wireless you can change the location of router, use a wifi extender and doing some changes with the advise of the support staff or can consider doing the wiring. For small HDB unit just need to make some changes will be able to resolve the issue. Just need the help of professional people. For ST Support, we can request to get someone a bit senior and really know what is networking to come to our home. There is always a solution and wiring up is the best. Most professional contractor can really do the wiring nicely just need to tell them loud and clear what you need and discuss with them before they start working on it. For wiring, getting a good quality Cat 6 LAN cable is best.
