CoolSilverRider
- Sep 4, 2008
I'm now updating to 17.1.A.2.69.
sometimes battery low till cannot turn on.
Charge it for at least 10 to 15 mins on the original cable and try turning it on.
Happen to me before
For ****'s sake dont use those third party cables. get the original Sony ones. Plenty of cheap original online on qoo10 etc. third parties are so poorly made that your phone will consume power faster than it can charge.
ehh they rolling it out in phases ar? mine no new update leh![]()
Whete to set sensitivity?
did any one encounter this problem before i think a bug in software sometimes when i put the phone for charge lets say at 50 % after 1 hour it stays at 51 and heats up , if i restart the phone and then put it back to charge it charges normally , I hate to master reset ,,, but do you think that is the last option ?
updating now using SPCC
Wah so dangerous ah? Accidentally put wrongly for magnetic cable then will spoil
I bought the rocky hub one dunno safe anot
Will your phone explode if u use magnetic charger and micro USB charging together? Haha
