Average cost of custom water cooling loop
zetken
have.....
oh!! i want the whole piece sleeves from the modular port haha!
So, cant use it to soak ah? Then lemon is ok?
can ah.. the mild acidic will help to clear the inside of the radiator. lol jsut soak around 30min enough already.. more than that i think will bad effect i think.
remember always to mix with warm water. lol
zetken
Guys just wanna ask. The alphacool rads iirc have 6 ports of config for water to go in or out. Is there such things as if i were to let water in from the left inlet and let the water out from the right?
i think can.. as long there is only 1 in and 1 out. lol
shadow84
You wan sleeved cable directly for psu, then two ways nia. Either diy or get from moddiy.com or congrade07, depending in the psu you are using...
Yureak
Or evga or corsair have their own kits. Evga expensive but corsair one is cheap
shadow84
i thought i saw normal price 30-40usd for a set
Gt normal sets at $32.99+ and gen 2 at $79.99. Note that they are in usd and gt shipping charges to sg. The cheaper ones shld b gen 1 or sumthing....
gaoxing84
Corsair sleeved cables must wait for deals, like previous one at 50% off...
yup. got it for $80 sgd including shipping for full set of sleeved cables. abit rigid the cables and got heat sink at the front but still cheap.
full set for AXi series. including ATX 24-pin and a bunch of other cables
shadow84
So whats the diff between the $32.99 and $79.99 cables?
congrade07
Actually got difference de. Corsair/ Silverstone/ EVGA kits come in default lengths (60 - 65cm). If you need longer lengths then you need extensions liao, if need shorter then u need route the excess cables behind.
Their cables are also very stiff which makes routing and management difficult.
My cables are very flexible and can custom length from shortest 10cm to 100cm also can. I personally used 50 - 100cm of cables for my STH10 build. I have orders from some bros for their ITX build which goes as short as 20 - 25cm max for their cables.
Lai who keen PM me!
EienShouko
Local never bring in the corsair sleeved cables?
Tsk. More things to import.
Edit: Sounds good, congrade. Will PM you when I buils.
Assault
Tio poison
couldn't resist the poison after all the good reviews in here...
now just got to wait for the new hoots to arrive!!
shadow84
Nice! look thru the catalogue before and found that SM8 suits my needs... But the prices are :s22::s22::s22:
Assault
haha hi bro, yes, that's right, cannot resist the extreme poison in this thread la!!
Assault
well I looked at the cost, and compared it with the 900D price ($490 from t258jgn), this is about twice the price (all things considered)... I think the 'kick value' is definitely more than twice of an off-the-shelf item so I went right for it.
Plus can get 6% cashback from my credit card (LOL!) so why not!
The long wait for them to build and ship the case now starts...
congrade07
Trust me, the quality you get from Caselabs is a lot a lot better than corsair. From the full alum build to the powder coating. Its worth every penny. This case is build to last, only complain I had for caselabs is their screws. TMD not stainless steel and it will rust. Yes, mine rusted coz of my sweaty hands and fingers from building the rig haha. Need to change some of the rusted screws soon.
I did complained to Caselabs about the rust issues and they are very good. They mailed me a set of brand new screws straightaway. Not only that, my HDD cage and radiator stands arrived with some issues (not the right color and the cage was a bit bent). They also mailed me a brand new set of cage and radiator stands without asking me to return...
Thumbs up for Caselabs!!
