Sony Xperia Z2 - Sirius-ly A Good Phone
hush66
guys, just a quick recap as i forgot which page you guys mentioned this.
is there a dimension difference between L50W and L50T? Can i buy a casing that states L50W?
According to this page, the dimensions of the L50W matches the global version of the Xperia Z2. It's the L50T that has a different dimension (and also mentioned by Xperiablog).
anirudhks
just got an email form singtelshop saying Z2 back in stock and can purchase...
smart band is the gift
k0g3pAn
just received my smart band too... no queue at all as of 3pm... staffs are friendly and helpful and will guide u in setting up the smart band
enriqueyang
My Singtel set still can't update
Model number is d6503
Those who can. Update what is ur model number?
earthtk
So glad I got exchange the 'singtel' set for a stock sony set=X. Off the bloatware!
What I notice from new firmware:
1) File commander allows transfer between external and internal memory
2) Random intensity of vibrations (haptic and notification) are solved
3) Double tap is more sensitive now
I see the price from some online shop hha.
I would pay at least 100 for new one.
80 for used one ok but not new
Not sure about that.. Sony smart watch sells at 288 selling at average of 180 at hwz(correct me if I'm wrong)? So should be around 90 for a brand new one. Maybe if you wanna buy you should wait a little longer.
martian09
I set save photo to sd card but when I take a pic, it says sd card is full and it saves to internal. But my sd card is not full... Why is this so?
