I damn tempted to get the fisheye cam from D-Link sia...
Is the fisheye camera good from D-link ?
If I buy the export set, means it come with out the approved adaptor hor, will the unapproved one catch fire especially if the vstarcam is left 24*7 ?
After using the Eye 4 app for my T7838WIP for a few days I found it almost use up my data plan usage..I guess it's normal that I need more data if I plan to use my ipad to monitor ?
Or it would be better to use the webUI instead ?
Hi all, for the clicking sound in vStarCam T series even in the latest model it's still there. May I confirm there's nothing we can do about it ?
I read that there was a reply from the factory that it's a normal behavior for the camera.
Err, high resolution means more data flow, means more data usage. If you set 2048kbps resolution and watching, your machine is sending our 2048kbps to you, so over a long period of time, you can imagine how much data you use. I use WIFI if I need to be a "security guard" while I work
Relay clicking sound you mean when camera switches between IR to non-IR?
Oh ya resolution settings..ok thanks i will lower it but where would i set the resolution ?
My are pretty loud clicks but properly I get use to them.. I just ignore them though.![]()
Webui can set to precise. Phone wise is only factory's setting
True.. 3 of them "click" sound more or less the same noisy.
Hopefully the latest shall less noisy or very soft "click"..![]()
Neh. I doubt so. If minus tat click sound. It shld b one of the better cams out there.
gecko, not really though..Depends on how makers do, Quality =/ quantity. Now because of the relay still cheap to produce and min heat generated, so still popular to apply most of the electronic gadget. The downside is it takes up more current.
While the substitute of relay is an electronic relay called SCR. Pro side is its light weight, easy to produce and less current to operate. Con side is it generated more heat and need to implement protection circuit due to easy damage.
Hopefully there is a hybrid product in future though..![]()
