enriqueyang
- Dec 4, 2003
The link from xda is no longer working.
has anyone reupload?
if not i think i just reupload
but anyone who own both expensive IEM and this sony earpiece can make a short review?
as in they say the new michael jackson soon to be released are tune for the headphone, how good the earphone really is?
did you manage to resolve the issue yourself or send for repair?
doing a reboot with power + vol up solved the problem for me but the problems will resurface once i plug in (usb) to charge.
No one has reuploaded the file yet. Appreciate if you can upload the sg ftf.has anyone reupload?
I can power the phone back up and use it almost normally except for all sorts of weird behaviours while charging. Exchanged the phone for the gap issue.
Woah where did you go/what did you say to get an exchange? I went to Sony on three separate occasions to try to get an exchange but no luck. I emailesd them too and they said it's 'within manufacturing specifications'.
this show that Sony have no confidence in future manufacturing issue, any problem of the phone will fall in this 'within manufacturing specifications'. Really need to consider more before buying Sony phone in future, they got a very low manufacturing standard.
oh yeah, can we consider the Z2 a 'lemon' and demand remedy?
Consider the Z2 a lemon because it collects dust on its bezels? From a lay perspective, I don't think that is sufficient to consider your device a lemon, however 'ugly' the so called gap might be.they probably just say that to absolve from all responsibilities; the gap is very bad. on my white Z2 a lot of dust has already built up in both front and back bezels and i don't even put it in my pocket that much (usually hold in hand or put on office table).
No, because cosmetic issues do not impair the functionality. If it dies on it's own after a week, it would be a "lemon".
got a little hopeful cause of this http://www.case.org.sg/downloads/central/Lemon Law FAQs.pdf
“Satisfactory Quality” includes their state and condition, as well as
the following aspects:
(a) fitness for all the purposes for which goods of the kind in
question are commonly supplied;
(b) appearance and finish;
(c) freedom from minor defects;
oh man... since i can't get it exchanged, does anyone have tips on how to clean out dust from the gaps?
my back panel is slightly shifted to the top right, creating a gap along half of the perimeter. the dust that got inside very hard to reach![]()
Normal longer ringing?
Means what?
can you show pic of the current dust accumulation? i have some dust in between my bezel and glass sp but i dunno if it's the same as urs
