Sony Xperia Z2 - Sirius-ly A Good Phone
fatangel
Do this for singtel(30 seconds):
**61*1389*11*30#
Anything longer you have to contact singtel. This was what I did 2 years ago when I had my s3
Cool . this is new to me. Now I know :) Thanks.
Also I just did a call to my own mobile, it rings for around 1min before it stops.
archkiller
Those who have sent their z2 for repair before, how long does it take for ur phone to be back?
anirudhks
**61*1389*11*30#
tried this on my singtel the phone message was call forwarding set succesful and when i checked my settings for call forwarding it was set to forward to 1389 when not reachable:s22::s22::s22:
Ohayo!
What to do to solve the soft notification ah?
If play it once its soft..play it again then it will be louder. But when the notification play the sound it will be soft
PongRareRare
hush66
sry i'm new to all these "flashing" thing.. after we flash this firmware, for the next update, do we update as usual from pcc or we have to flash manually?
For the next update, you can update via PC Companion or flash manually again. It's up to you.
This firmware is provided for those who have not received the latest update via PC Companion and don't want to wait.
ZM0126
Hi, guys, may I ask is it the smartband must be collected by the one who sign the contract? Or third party only hold that redemption letter is fine?
Slammer
mlwang
hmm why the hurry to upgrade to .69? I upgraded and find that the only changes seems to be better double tap, and some layout changes in the Sony Apps. Other than that, can't see the major change.
hush66
Just to be sure before I proceed... has anyone successfully unlocked the bootloader and updated to the .69 firmware posted by anirudhks?
Such stock firmware files can be flashed on both unlocked and locked bootloaders.
Personally, I won't advise to unlock the bootloader unless you really need root. For one, you can't backup your TA partition now (since the tool to backup TA partition requires root on a locked bootloader and you'll lose the TA partition as soon as you unlock the bootloader).
What's your intention of unlocking the bootloader?
anirudhks
hang on why are you unlocking your bootloader? you dont need to unlock I updated it without unlokcing the bootloader via flashtool
Bulletbreaker
Never unlock the bootloader, as an ex Z1 user, only unlock if you know what to do such as using different kernels or testing out new package, yes I've helped out in that using the Z1 ;)
