Samsung Galaxy Tab Pro 8.4
zXioNGz
Gotten my find 7a ytd from adix. it so light and smooth os.
How's the Battery life? It's only 2700mah for 1080p 5.5incg screen right?
Should be a little heavier than Note 3 but negligible at only few grams.
garychengjw
Eh. I came from nexus 5. It felt lighter.
Can't said much abt battery life yet. Gimme a few days to test.
But the fast charger imba. From 36% to full within 30mins. :)
yiptw89
Good question, I wish to know too
But so far I see review they show on wifi version has it? Not sure about LTE...
It seems that Singapore version doesn't allow us to create multiple users. Even for Wi-Fi versions and other Tab Pro series.
Anyone successfully install WatchOn app to make use of the IR blaster on the tablet?
zXioNGz
Huh how come? Don't tell me IDA blocked it, that's weird thing to do....
I tried IR blaster, not bad, but sometime laggy, and I find remote controller better, cos got the button feeling against touch screen have to keep look at the screen to touch correct buttons
yiptw89
Not sure why. I went to Challenger to try out the demo sets and I don't see that settings on all the Tab Pro series.
What app did you use to make use of the IR blaster?
Livewings
You're right.
I didn't even notice the multi-user option was missing.
I'm using Peel Smart Remote.
I install WatchON says restricted to US.
jayz89
hi all,
am here asking question about samsung galaxy tab 3 7" lite, do not want to start a new thread for it
brought it from qoo10, the device doesnt come with chinese lang, any idea how to do it?
my dad dont know how to read english, he lao kor kor liao
Model: SM-T110
android 4.2.2
build no. JDQ39.T110XXUANC2
appreciated
teojm92
Just some inquiry I want check before making up my mind to get this tabpro 8.4.
is it easier to use than ipad mini?
is this laggy?
Are there better option for me to choose from?
Will this be able to last me for two years?
This is a first time I will be getting a tablet. So I wanna to make sure I wont regret.
thanks alot
kurt111494
depends on individual preference. best for you to go down to a store to try.
is this laggy?
maybe a little for highly demanding tasks? then again, perception of lag also depends on individual. best for you to go down to a store to try.
i would probably say that its equal or rival would be only the ipad mini 2? for other alternatives, they will definitely be less powerful (LG G pad 8.3, Galaxy Tab 3 8.0, upcoming Galaxy Tab 4 8.0 etc...)
if not, you can wait for the rumoured Nexus 8.9 as well, though that will take quite some time...
definitely if you take care of it. just don't toss it around and all.
Lacenta
Hi,so I recently bought a case cover for my 8.4 from qoo. I realized that the magnetic part that is used to cover the flap,seems to interfere with my tablet when it is very near,like when I flip it behind like a book. It causes some buttons to not function at all and when the tablet is far from the magnet,its back to normal. Does this happen to any of you guys? Is it normal or just me?
tamahomy
3rd party magnetic covers may have this issue. For previous owners of the Note 8.0, some of them said the magnetic functions of 3rd party covers interfered with the S Pen.
Had the original Samsung book covers for both the Note 8.0 and Tab Pro 8.4. Never had such issues. ;)
qifatt
Original samsung cover is very expensive. Got rock cover from adix. Cheaper and good
chngz8
do you all find the tablet abit laggy? Seems like there is a noticable lag when i press an icon and it popping up on the screen?
Lacenta
@tamahomy and @qifatt
Thank you for the info,I shall head down there soon haha.
To the above poster,from what I know android tend to be chopp/laggy when opening apps or scrolling,that happens to even high end models afaik. IPad will definitely be smooth
miragez
fwaaahhh AMOLED display at 2560 x 1600 pixel reso , 3gb ram, Exynos 5 Octa :eek::eek::eek:
That is only rumour, till it really outs then I will be super happy to get it. But.... why not SD 801 :s13: this means charging port might be a usb 3.0 or the usb2.0
Anyway here's my source of information regarding this is a rumour.
article here
