How do we optimised the photos? I know for other phone we can choose finest, fine etc but don't think we have this function
Only in Manual Mode, then u can choose the resolution of your photo.
all update are carrier dependent dedidn't know this update is carrier dependent... why can't it be a universal update...
Only in Manual Mode, then u can choose the resolution of your photo.![]()
Anyone has this odd issue where sometime you cannot turn on the Wifi? Need to reboot the phone before you can turn on.
Sometimes I notice when I get home that it does not connect to my home network and when I try to on it, it does not turn on.
My ST set automatically comes with .69 and all other updates updated liao
hmm....then what are they testing????![]()
The Z2 allows you to select image resolution but I don't think it allows the user to choose between finest, fine etc (the level of image compression).
Question on manual OTA update.
Using flash tool with branding SG@UXT 17.1.A.269, the various options need to tick or not?
They refer to different concepts. Fine/Superfine etc usually refers to the amount of compression that you apply to the photo. For instance, Superfine applies less compression than Fine, therefore giving better image quality at the cost of larger file size (because of the lower compression).To me, feel same just some term use by different company.![]()
wow z2 without contract drop from 890 to 840-855![]()
