andr3wyong
- Mar 5, 2012
OpenNet provides dark fibre, so no issue running 10Gbps (XGPON) or even higher for direct fibre links (non GPON)Actually is the current opennet able to support 10gbps or there be a upgrade in few yrs to support future higher plan?
With the goverment plan to block torrenting sites, let see how this goes
If you (or your company) needs 10Gbps and has the budget for it, speak to @viewqwest
