Have been stuck with 55 and have gave up hope of upgrading to 69 ...
suddenly today saw got upgrade ... wahthe feeling is like strike toto like that ...
but it did not upgrade to the latest 69 leh ...
my build number is now 17.1.1.A.0.402
Android Version remains 4.4.2
So is my build number the latest ?
Thanks
Go safe mode to uninstall?
Why would Sony and Starhub give you a new set? I wouldn't.Urgh stupid mistake, my beloved z2 dropped accidentally and now there's a small dent at the top on the purple rim of my phone.
my phone cover does not protect the top part. Any way I can exchange for a new z2 with Sony/starhub? It looks really ugly and is quite obvious![]()
Okay So i called starhub. They told me that I'm eligible for 1-1 exchange for any kind of accidental damage (smartsupport value-added service) at a flat fee of $130.
Now just thinking whether it's worth to pay $130 for a few small dents at the top of the
Phone...
just came back from holiday and found that the camera will sometimes hang for no reasonanyone else faces the same problem?
I encountered a few times where it will auto restart. Hopefully it will get better once I update to the new firmware. Mine is still .69
i'm already on .402 ....its quite jialat for me sia. the camera buttons will all disappear and i will be stuck in the app, can't focus, take pic, do anything. have to lock the screen using the power button and unlock again to solve it.
sometimes a sudden change in exposure(very dark to very bright) will also cause this to happen. pek cekkkkk![]()
And occasionally recording video in superior auto will cause the screen to freeze, but the recording continues; after awhile it will auto shutdown and the video is not saved.
honestly, all the issues so far i ok, very easygoing one..but this one is quite annoying. this will probably be my first and last sony phone![]()
Seems like your issues are more disturbing. You might want to send to service centre. I think every brand will have such issues depending on your luck
I see. It seems not easy to find 128GB MicroSD card around so I bought the Strontium 64GB Class 10 MicroSD Card, the speed is the faster in the market.
Phone...
Any one experience the tap to wake up is not responsive?
If I leave my phone in standby for quite sometime the tap on the screen will not wake up the phone and I need to press the power button, otherwise the tap to wake is ok. Is this normal?
I am not sure its the screen protector as everything works fine typing, tap or swiping on the screen works.
