Sony Xperia Z2 - Sirius-ly A Good Phone
hush66
Found many thanks.
Been using the phone for a day, overall quite positive.
Only complains.
1. My swift key doesn't have haptic feedback.
I had the same issue. But after updating to the latest version of Swiftkey earlier, I was messing around with the settings (nice new themes!) and found that you need to increase the value of the Vibration duration setting for the vibration to work. Default value is 10ms and I adjusted to 50ms.
recca85
This phone would take a very long time to charge or won't charge at all with a normal android charger, only the charger that comes with the phone itself, would charge it but I need a charger with a longer cable like 1.5m cables, anyone got any chargers to recommend?
Actually, you need to give more info. The sony charger is just 1.2-1.5A(can't rem but I think its 1.2A).
How many A is your normal android charger, there are so many, even <1A.
How is ur power consumption of phone when you are not charging, did you rem to off the screen after connecting the charger? The screen will turn on when there is power.
If your consumption is low, there could be something wrong with that charger or even phone.
Yes, 1.5m or long will make charging less efficient but not a big deal compared to the A capacity of charger.
I am using 5m cable with original z2 charger and it works fine.
yhw22
If your consumption is wrong, there could be something wrong with that charger or even phone.
The Sony charger provided in the standard package is 1.5A :D
recca85
Oh ya, thanks.
Btw, One has to rem Z2 battery is huge.
3200mAh.
Ideal case, 3200mAh /1.5A around 2hour plus for full charge.
Add in losses and consumption, it can take 3-4 hours to full charge on 1.5A original charger.
ondisplay
Oh ya, thanks.
3200mAh.
If I use the charger and cable that comes with the z2, it would take 2-3 hours to full charge but if I use the same z2 charger but change the cable it would take 10-15 hours to fully charge...I google on this and a website said to just use the charger and cable that comes with z2 so I thought it was normal, this website -----> http://m.digitaltrends.com/mobile/xperia-z2-problems/#!XlDxR
rubber33
Yeah.. Was playing around too.. Lol
rubber33
Wondering how many of you shoot with 20 mega? Feel quite stupid that the auto setting only for 8 mega
fre3dom85
Was shopping around and saw s5 low light performance.. Damn powerful...
well imo i am happy with my purchase, so long as the camera does not fail me when i need it.
Anyway is there anyone who are looking at cm11 for this phone? i can't really seem to find alot of information about this. I do not even know if there is nightly build.
hush66
how to go to fast boot in z2 ?i wan to unlock the bootloader
Hold Volume Up key while connecting the phone to the PC.
http://forum.xda-developers.com/showthread.php?t=2768332
Wilfordgoh
True... Oem cable quality also varies very much and low quality cable will result in extremely slow charge. I have bought those 3m cables online to charge my previous S4 and overnight, battery increase by less than 10%!:s22:
Oh ya, thanks.
3200mAh.
I do uses the old original iphone 1A charger with magnetic charger. Takes about than 2 hours (excluding tickle charge). Same charger when using DK36 takes about 30 mins more...:s22:
Wilfordgoh
If I use the charger and cable that comes with the z2, it would take 2-3 hours to full charge but if I use the same z2 charger but change the cable it would take 10-15 hours to fully charge...I google on this and a website said to just use the charger and cable that comes with z2 so I thought it was normal, this website -----> Xperia Z2: 6 Common Problems Users Have, and How to Fix Them
From this description, 99.99% is ur this cable is spoil or lousy... :o:(
Wilfordgoh
Anyone mod the dk36 to fit the phone with case?
Why mod? What case you using?:s11:
The DK36 comes with interchangeable slot so just change to the bigger 1 shd fit ba... I was using Casemate barely there with Nillkin Glass SP also can fit... ;)
I have also seen in earlier post that some1 uses a file and sand paper to "enlarge" the slot...:s22::s22::s22:
rubber33
Mine is aftermarket.. Don't have bigger slot.. Haha
