The Samsung MicroSDHC is being put to the test! How much torture can it withstand?
fireduke86
Why Samsung?
Number one in memory since 1993, Samsung has a solid reputation for manufacturing high-performance, top-quality, premium-designed products. That's why Samsung memory cards are the trustworthy choice for recording, transferring and protecting your precious images to recall time and again. Samsung uses the finest-quality NAND flash memory chips, fabricated from its own lines to ensure the best quality. Our quality control is second to none and our more than a decade of experience in NAND speaks for itself. So don't store your priceless data in just any memory card . Put it in the hands of the company that device manufacturers choose most often - Samsung.
Quite true, I am quite happy with my 830, 840 Pro and 32GB Plus~ :o
noobiee
Erm anyone know the 40% can use at which shop?
Where to check the retail price of each individual Samsung micro sdhc cards?
bizmind
Rewardslink Redemption Centre: Sim Lim Square, 1 Rochor Canal Rd, #05-03, Singapore 188504.
**Read under Fine Print after you click "Rewards" on the Samsung pop up at the bottom left hand.
Amuroraysg
So we buy it at the center or just for redemption only:s11:
jeff79
Seem like saljiputeh and MoneyFace =p got 10 points without any new post and more than 36 points cap. :( They got the bonus points?
Amuroraysg
Samsung Evo Series Micro SD card transfer Faster
Transfer 360 photos per minute. With a transfer speed of up to 48 MB per second, you can spend less time transferring memories and more time making them.
mosmos
High Honorary Member
Anyone get the secret question is?
Is the Samsung microsdhc cards water, temperature, magnetic and x-ray proof with the ability to survive up to 24 hours in seawater, survive in temperatures from -25° to 85° Celsius, protect user data from damage caused by airport X-ray machines and resist up to 13 times the magnetic force of home theater speakers?
:s22:
Nakedtoes
:s22:
Why Samsung?
Amuroraysg
Why Samsung?
And it comes with 10 Years warranty...
Claiming warranty via receipt? by 10 year receipt might have faded :D may need to get a copied using photocopy machine for safe keep
Amuroraysg
I wonder how they give point? specifically, do i need to post only 1 once every an hour or something? i post 2 comment and yet no increase in point...
