The Samsung MicroSDHC is being put to the test! How much torture can it withstand?
CallMeKing
After reading the replies here, the more I would like to get both the EVO and PRO Samsung MicroSDs =:p
including the following SDHC
Unfortunately this model doesn't retail here. Amazon has it for 29 USD..
Perhaps the 32GB SDHC pro is good enough for a backup storage for your photography gear or any devices that is reliant on SDHC. Well you could use the microSD + adapter but I am not sure whether this combo is feasible in the long run (so far not much info on the durability of the adapter provided).
Why get 32GB sdcard only? Nowadays 64GB sdcard also getting cheaper can just whack a 64GB sdcard for more storage ma?
CallMeKing
Samsung EVO line was launched alongside updates to the PRO and Standard SD and microSD cards, all of which are designed for different levels of high end digital imaging and mobile devices. We found that the 64GB Pro card to be one of the best, if not the best, offerings of its class. This time around, however, we will be looking at the Samsung 32GB EVO SDHC card, which offers a more mainstream profile than the Pro line. Even so, Samsung’s new EVO line of SD cards are still specced to offer decent speed and performance to enable full HD video recording and high resolution pictures. Also worth noting is the new EVO branding for memory cards, which shares that of Samsung’s line of high-performing but value-priced SSDs.
As for the specifics of its performance capabilities, the EVO line of SD cards support Ultra High Speed (UHS-I) Class 1 level performance and are quoted to offer read speeds up to 48MB/s. For write activity, Samsung simply states that it is “slower than transfer speed.” Like the other newly released Samsung SD cards, the EVO line is designed to withstand some pretty tough conditions, this includes being water and temperature-proof, withstanding up to 24 hours in seawater as well as in temperatures ranging from -13 to 185 degrees F. Additionally, Samsung states that it also protects user data against damage caused by airport X-ray machines, resists up to 13 times the magnetic force of home theater speakers, and can take a hit-and-run by a 1.6-ton vehicle and survive; well intact.
Wondering will Samsung comes out with 128GB card with those protection??? Anyway got any device can read more than 128GB Sdcard??? LoL.
shadow84
Mogan23
Wah moneyface 400 points already. Go redeem tmr since today hari raya ??
mosmos
High Honorary Member
Are you guys getting the Samsung MicroSD Evo 64GB or Pro 64GB?
The PRO may be a bit overkill but I foresee it will serve one well in the near future.
- Rave reviews regarding it's usage for DSLR and Mirrorless Cameras
- Reliable and consistent write speeds comparable or in fact better than some of the leading brands out there
- Phones starting to adopt 4k recording
- Currently most bang for the buck high end SD card here. Even the professional lexar series do not come with water, temperature, x-ray and magnetic proof capabilities.
I think 40% of retail price for the Pro 64GB is not that bad of a deal. Even cheaper than amazon if you think about it!
Yes, i think samsung evo mirco sdhc is very good for most users, unless as their naming of the top series for Pro~
ursula
Samsung EVO & PRO 64GB cards are SDXC, while 32GB & 16GB are SDHC. Same application is it?
noobiee
Challenger selling 64gb plus for $59.90 member price leh. It's the same version as evo right? Only the color of the card itself is different?
dexmus
Lol this 2 3 days the thread will evolve about how gotten the free card liao !!
waiting for ppl to go redeem and come back to give a review on the samsung micro sd card. :s12:
if i remembered correctly something got to do wif the technology they used is slightly different between 32gb and below cards and above 32gb cards. i might be wrong though.
