Hi, the antenna needs to maintain line of sight to the open? Meaning, if I keep it inside the tv console, does it still works?
My antenna have to be placed at the window facing outside for proper reception
I stay on the 2nd floor, surrounded by HDB can get signal w antenna. My area is also one of the areas due in 2015
The only problem is that there's just one sweet spot and if you move will lose signal, so if you find dont go touch lor
Thanks bro! Very helpful indeed!
Samsung 48H5100...What tv u using?
Hi bro kinki you have to use an indoor antenna, or the Playon! Booster Antenna. Connecting to wall jack (SCV) will not get you the DVB-T2 channels.
OK. Finally a 15 meters Belden antenna does the job pulling the signal from one side of my HDB to another where my 42" TV is.
Now I can really see the Glee concert in full HD on the big screen so clear and sharp. Nice!
A small project as learned from this place...
1 set only cost roughly $2.70-2.90!![]()
15metres antenna?
you mean the cable 15metres or the span of the antenna is 15metres?
Bro can share where u get the parts especially the socket part
Can't buy the Balun transformer any longer from UF Tech in SLS... any idea where else I can get one? I asked a few shops in SLT even the one I made cables from and they don't carry it.
