Hi Bro,
How much are you selling the wheelies? by the way, what's the typical travel range?
I got my X8 a couple of days ago. I also bought the rubber bumper to help stop scratches during my learning phase
But...my X8 didn't come with any of those orange rubber pads for the sides where you grip with your legs. After a couple of hours it begins to hurt.
Does anyone know where I can get those on their own?
eh bullfrog..
how to get on it without falling down huh...
eh bullfrog..
how I do it: (i left master leg. Do the reverse if you're right master leg)
Right leg on pedal, left leg on ground.
tilt airwheel at a comfortable angle to the left, with the left feet still on the ground and right feet on the airwheel, keeping it tilted at that angle.
Do a very slight push off, while at the same time bringing your left leg up and airwheel vertical. My left foot needs to get onto the pedal at the same time the airwheel (and my body) goes vertical. Gotta practice this till you get the timing right. No kiaping required
But I must admit, padding or calf guards helps while learning to mount cos it can get painful during the repetitive motion of learning to push off.
However, once you finally work out the timing, I don't see the need for padding already.
was interested.. ill i saw the price of it... think is at least $7xx and above.
bullfrog bro, join us whenever you are free. We normally wheel on Sun.![]()
Love to. But I don't drive and I don't really want to lug the airwheel around once it's juice runs out. (unless there's a charging point nearby)
I basically just use it to wheel around my estate when I go grocery shopping, visit my parents or lim kopi with friends (those staying within a 5km radious from me)..It definitely beats walking. Absolutely love it!![]()
looks interesting ... seems like the duo wheel q3 is better ..... any comments ?tks
Hi could you pm more details of the price package for this wheely unicycle and if there's a shop for me to take a look? Thanks!
Hi fellow riderS. I just got myself a q3 few days ago.. gt a qn, how often do u guys check the tyre pressure? Do you all use the manual pump or go to any petrol kiosk to pump air?
Tks...
