May I know what is your 7003 version?
You meant mine? How to check what's the version? Haha
Today Singtel just came and changed my modem to this since I recontract to 500mbps, but even after installation, I use Speedtest but still see only 200+ mbps... Afternoon tested and now at night also, anything I should configure on my side to achieve 500mbps?
Thanks in advance!
Normally...the technician will do a speedtest for u b4 he left....or maybe ST havent open up the speed at their backend...
Hmm because he fix it while my Dad at home I'm not present, not sure if he did a speed test.
But maybe like you mentioned, the speed aren't upgraded on server yet.
Well u can always call them up to speed up the process...tats their service...
Coz my 500m is recontract on last year dec. So 7003 havnt come out yet. And called singtel ask them can i change my 7002 to 7003 they say need topup 100 plus. If yr router faulty they can change for me coz under contract.
anyone using 200M on AC router?
what's the speed i should be getting roughly on wireless?
need a benchmark
Up for u.... I oso wanna know
Right beside the modem on 5ghz I get 15xmbps.. 1 floor above with still full signal on 5ghz abt 12xmbps.. 2 floor above on 2.4ghz I got abt 30+mbps
My laptop doesn't support ac tho.. Shld be faster if it supports wireless acThat's pretty fast! You are even getting high speed on wireless for just 200mbps
Pardon my noobness but what is AC? I'm not sure if my laptop support it but it does showed the 5.0G
how is this router compared to the ones that Starhub and M1 are giving?
is it good?
i hope this is better than my existing 2WIRE router.![]()
is it good?
Do you know what is the specs of 2wire? 2wire do not even have dual band which is so common today. 2wire is so old and the specs is really very low end. The new Aztech FG7003GRV is same same as ASUS AC56S but I think ASUS router support 3rd party firmware. Aztech can not support 3rd party firmware. Suggest google for the specs. This 7003 is quite fast.
