Digital TV (DVB T2) in Singapore [consolidated]
Ah Ken
Jeremy,
thanks for the reply. I am staying in Sengkang. The indoor antenna you talking about is the antenna Marcon brand at compasspoint best denki selling at $39 is it??
So no need to buy the tvb box right?
Have you tried the changing of region settings method as suggested by some one here? I am having the same remote as you and afraid to mess around with the settings, or rather cannot find the settings.
Hi there, I am staying at Punggol. Using that Margon antenna you mention. My antenna is facing Pasir Ris. Signal is good as I hang on my window. Sometimes signal do get lost but it happens quite rarely. Just have to adjust a bit. I received all HD channels and SD channels. Also some other channels.
To fellow bros,
Those other channels I receiving are Indonesia one is it? And is it possible to receive TV1 and TV2?
Thanks!
kwchang8099
Staying in Yishun. Able to receive most of the FTA channels including Malaysia and Indonesia.
TV: Pioneer PDP-427XG (very old plasma tv)
Antenna: AmazonBasics Ultra-Thin Extreme Performance Amplified Indoor HDTV Antenna
digital box: Draco HDT2-7300
Setup: feed antenna signal to plasma TV and Draco HDT2-7300 using "starhub mixer".
Plasma TV Tuner: Malaysia channels -> TV1, TV2, TV3, ntv7, TV9, 8TV
Indonesia channels -> RCTI, SCTV
Draco HDT2-7300: 5 (HD), 8 (HD), Suria (HD), Vas (HD), Test, Ch U, Okto, CNA
Jeremy1
My living room windows facing north direction. I placed it in between my window grille and window glass panel (that glass panel in closed position and still able to receive good signal)..
Too bad, my window is quite far from my living room, if not should be able to get clearer pictures.
Finally got my position and managed to get 12 DTV Channels and 15 Analogue Channels.
MoneyFace =p
There is no cable setting. only analgue and digital.
I think need to do the extended service menu thingy. but too cheam for me.. scared spoil my TV.lol
Setting Auto Tuning will provide you with the settings....
MoneyFace =p
With that, ALL TVs with DVB-C tuner should be able to receive all Mediacorp HD channels without sticking any ugly antenna out to the sky!
P.S: And btw guys, i've already retired my DIY $2.50 unpowered antenna into shelve since we do not need them anymore!
Jeremy1
Did u go into the service manual ?
Did need to put outside to receive Malaysia and Indonesian Channels.....................:(
Jeremy1
Never :)
However i've never receive any foreign channels either on DVB-C or T2... :o
Because my TV no Cable option but i still can receive all the HD channels
easily.
Now trying to receive foreign channels. Managed to get them but not very clear.
Jeremy1
I went into auto tuning. Only Terrestrial option. No have the cable or air that was shown in your picture...
Dun know why like that?
No worries, it's the same and you should be abled to receive all the 12 DTV channels at ease.
Mine also the same as you.
sparky3
Meaning. U use the Mohu antenna? Or you set the tuning as per moneyface?
My model is hu7200.
How the mohu?? Any good? U need to put near window or near opening. My analogue signal ok. But I think he should be much better. Review??
Jeremy1
My model is hu7200.
To receive all the HD channels, the mohu don't need to put outside the window. I can easily get all the HD channels by just putting the mohu on one side of the wall about 2 m high.
But to get the Malaysia and Indonesia Channels will depend a lot on location. I now put my mohu outside my window in order to receive better Malaysia and Indonesia Channels picture quality.
Would I advise you to buy the mohu ? :s8:
I think NO.........................;)
Ah Ken
My model is hu7200.
You can try the margon antenna. Think there's a 2.0 and a 5.1 version. I able to receive the channels already. Except for Malaysia channels.
