One star for Spigen iPhone 6 Screen Protector GLAS.tR SLIM
kultarr
Paid $$$ and applied the Spigen iPhone 6 Screen Protector GLAS.tR SLIM and the size specification is out!!! The width of this screen protector does not cover the entire LCD screen on the phone leaving a visible gap between the protector and the LCD. Please stay away until they fix this.
Revenent
Yes that is correct. All the glass screen protectors now all will only cover the maximum width of the display screen which is 4.7" for the 6. Reason is if you look closely from the front of the phone the edges actually bends downwards to meet the frame of the phone edges.
eddy2099sg
Yup that's true. The glass screen protector can only cover the straight part of the screen. The edge of the screen which merged with the metallic frame is rounded and the protector is unable to cover that. Only the thin film protector can wrap around.
foopower
That's for having a curved glass.
Look at the S3 and the Note 2
porcu
Yes, but it's very difficult to bend glass. I sell Polycarbonate,etc to replace those for automotive industry so I know.
So it won't be possible for small scale glass protectors for phones.
Maybe should go back to normal glass protectors. At least they are thinner and although they don't cover the whole LCD, the gaps are less obvious.
PetPet
Moderator
Moderator
It's like that.
The glass is curved.
It can be fixed but you might have to wait for later batches~
shaun166
hey, where do you bought it? How much is it?
