Any Hyundai Avante Drivers here?
banz86
avante 7.5 years already and still going strong~
regular servicing and take good care of the car and it will last for sure :)
Haha, although I'm not an avante owner but also a korean car owner.. 4.5 years and going well.
oddeye82
https://www.facebook.com/WhiteSnailPerformance?fref=ts
with him for like 4 years liao. price a little bit on the high side, but i would say its worth the money.
I went there 1st time for my last servicing and was given Motul EO. I also changed my rear shocks and stoppers and brake pads. Price a bit on the high side but I feel my car is more responsive. Not bad i think... Should be going back there next time..
biodraft
your current mileage how many ah?
seabreeze82
Spark plugs part number
Hi fellow avante bros, I m driving a 2007 Avante.. if I remember correctly I am currently using Denso iridium IXUH22, and I see on mxtrading web that they carry bosch plugs now. So wondering if anyone using bosch plugs nd what is the correct plug number?.. Many thanks
Didjerama
It depends on batch. If you want to be safe, go to a slightly more ex workshop e.g
Aoto
whitesnail
they will check for you. You go those anyhow one they will put one type only. Then just take note of the type for future changes.
kweeli
Hi bro... Anyone install RISK in their Avante. How the performance, FC n maintenance?some bro comment stock is already good...so thinkin shd stay stock air box or RISK setup ? plan to get 2nd hand de.
BlackIcE84
Hi fellow avante drivers,
I'm driving a 2009 avante. Just have two questions:
1) if I want to change to Denso iridium plugs, is it correct model IK16L for Iridium power? If I want Iridium tough, would anyone know the correct model number? Also, can I buy Denso from Song Yi? Anyone has experience with both iridium power or tough? Any reviews, especially on durability of the plugs?
2) secondly, my 5yr old car now has the steering wheel "kook kok kok" sound problem. Does anyone know what is the correct part to buy from Song Yi to repair this problem?
Thanks!
dreamer_toons
Realized that my 2008 windscreen washers are having problem. 1 side is dispensing water weakly while the other one dual to dispense at all.
Anyone know the possible cause of this problem and the charge to fix?
biodraft
Thanks!
Shell Autoserv, $230 can get it done
go songyi buy, i forget price, diy can liao. not difficult
FinchGuy
Use needle to clear whatever is stuck in the nozzles.
ralfale
Any workshop where I can change all passenger seat to power window? What's the cost to do this ?
taoentan
Hi does anyone encounter fuel consumation drop for avante.
Driving 2009 avante. Can drive around 580km for full tank but now can only drive around 500km for full tank.
Just change fuel filliter only.
Cheepoozz
auto or manual . mine get 680km if pump to the brim . 09 avante - mileage at 126k.
just wondering if any major things to change at this mileage?? my clutch pump drop lately and i had to get it towed:(
thinking of replacing clutch assembly, shocks, engine mounting and other steering bushing and hopefully drive all the way
lugia88
hmm me too, i used to pump 53lit (11km/lit++?), can hit around 600-620km on high way. but nowadays i pump in SG 98 .. can only got 10km/litr ..
btw when to change/where to change fuel filter? i have not done my ever since i bought my avante in march haha .. not sure if the owner changed too
