iPhone 6 PLUS Cases (NO SALES)
wirelesslink
Hello, I got a spigen ultra capsule clear for my 6 plus yesterday at infinite vivo, the soft rubber one. May I ask whether is this normal as there is this ' milky ' area at the bottom in between the lightning port and headphone jack ? Can anyone who has the same product help me out as you all know, new phone then very ocd towards these kind of things :s22::s22: If not i'll need to go down and ask them :s11:
[/IMG]
radzkal
[/IMG]
u are using capsule or ultra thin? im using ultra thin n i have the same thing but im not bothered by it. probably caused by the small hole there.
galliano
[/IMG]
Mine too. But it's hardly noticeable. Suspect it's the manufacturing of the silicon.
The casing is not as thin as I hoped it would be, but I guess it's got protection. All 4 corners got this air cushion bubble thingy. And the screen does not touch the table if I put it face down. Likewise camera lens is also protected. Best part is the casing is easy to remove.
I like
Alpha0
Using ultra hybrid here.
Have that small milky spot.
But its ok lah. At the bottom.
wirelesslink
I like
That's normal, due to manufacturing method; injection moulding.
Thanks guys!!! Another question, do you all think PSAJ is better than this case? What's the pros and cons of these two casings?
Alpha0
my personal opinion.
in terms of all round protection for my case , spigen ultra hybrid > PSAJ.
The ease of maintenance is much easier. Easier to take out. The fitting is perfect and tight enough yet flexible enough to take it out for cleaning.
The TPU + polycarbonate material ensures the above points.
speedster4005
the cutting of the glass just barely covers the display screen.
i'm using it btw..waiting for a better one.
Anything beyond those long edges of the display area, unless the ones designed for full screen cover, can cause "bubbles" on the sides. Dust magnet and will turn ugly later on.
wirelesslink
Thanks thanks! I was at infinite store, had the chance to buy PSAJ but chose the spigen one instead because the thought of hard plastic scratching my phone just makes me feel :( :s13::s13::s13:
weewee81
lightin n shootin skill not good ma + use 5S only.
like the blue lo... always like dark blue... gf like it also... haha
