Recover DNS320 Files?
croc1977
Hi all ,
I have a DNS320 . Configuration is JBOS not Raid ,
one 3TB and one 4TB. The Files inside is important to me.
Is there any way to read the files from external HDD drive?
Recently my files cannot be read . suspect one of the HDD or DNS time up? i want to back up the files . the 3TB HDD always goes missing after awhile while 4TB always can be seen so i suspect either 3TB cos the problem.....
so anyone can help? any program can read the program or should i just buy a new NAS and plug in?
albertlee
Seriously if your data is really that important, you shouldn't be using JBOD setup in the first place!
Now back to recovery, have you try connecting the working drive to a PC and using Linux Live CD or 3rd tools in Windows to access?
jtjt00
Assess if your data is worth the money for data recovery service?
croc1977
no lah....not that bad...
Just my retro cartoon i collected....cannot find.....
like MASK, Transformers series, Centurion , Starcom all in there...
wanted to share this to my twins when they grow older....
guess...plan can abolish....
quite surprise with seagate baracuda series...looks poor esp with 2yrs warranty now....
even my hitachi 160 gb and wd green 500 1tb last longer
croc1977
Try remove the 4TB
Plug the 3TB to the 4TB slot.
Good Luck.
try liao...
i even tloan a same dns from dlink for $50...
sometime can detect sometime cannot or can detect copy files 5 mins network missing
4tb no issue....
now using easeUS data recovery software ....still got 8 hrs to go....already found 6k files...
i hope can recover at the end of the day bah...
i can detect using hard disk dock but not both nas .....so can RMA?
Warranty till Jan 15....
Seedbox
My DNS320L also just uplorry. JBOD also.
Going to recover it using Ubuntu Live CD to transfer the data out and format the drive from EXT4 to NTFS.
albertlee
try liao...
4tb no issue....
Didn't know can t-loan set from D-Link but $50 is kind of expensive imo, should be able to purchase a 2nd hand set at this price. BTW, how long is the t-loan period?
croc1977
2 weeks...
If buy over , return old set and get back $25 which i tink is wu hua leh
3 mths warranty ...mine warranty long over
albertlee
2 weeks...
Definitely wu-hua if your unit is indeed failing, maybe can request for an "upgrade" to DNS-320L since DNS-320 is already EOL.
weiyang76
They will return you the $50 when you return the set.
albertlee
So basically one get to t-loan for free and $50 is what the loan set is worth to them should the borrower decided not to return it. Thumbs-up to D-Link!
cscs3
Even you are on RAID. If the controller dead. You are done for the day too. Many did not notice this and only focus on harddisk failure.
albertlee
Don't expect to find separate controller for such a NAS setup, the RAID function is done via software. Anyway, with or without RAID, backup is still needed if one truly value their data.
