Samsung Galaxy Note 4: Has microSD slot & removable battery
seller4
My Note 4's Play Store has been updated to Version 5.0.31.
Teo Ming Ern
More like only after 4.4.4, I've no problem with 4.4.2 on my tablet tab pro and Note 3
It's not just 4.4.4, it's all versions of 4.4... if you're using the stock apps in your device, you don't have a problem. It's third party apps that are the serious problem. For example, I can't delete photos off my SD card using QuickPic but can do so using Gallery. Basically Samsung bypassed the SD card restrictions imposed by 4.4 but most of the third party apps don't update their apps to allow it. They need to work with Samsung to enable that function in the OS kernel or something like that... which is what Google doesn't want to allow as it will allow malicious apps to take control of your device and can basically turn it into a bot without your knowledge or steal your data as you use the phone or tablet.
Teo Ming Ern
SNIP
As for the cursor randomly stopping in the textbox in the HWZ forum, yeah I've encountered that randomly too but I've never been able to reliably reproduce the bug. The HWZ text entry box isn't very mobile-friendly, so I don't know whether it's the phone's problem or the site's problem too. When I tried reproducing the bug on my bro's G3, it stopped happening to my Note 3 as well. Zzz.
It's HWZ's coding for mobile... it's crap... if you load the page as a full webpage it will be ok. It's the mobile version that's broken. Using an S4.
zXioNGz
Nah confirm not all 4.4 because my Tab pro at 4.4.2 and note 3 doesn't have this issues I'm always using Mx player pro for movies
rachdanon
Elsewhere I also have this problem. Mibbit if I'm not wrong.
human_shieldz
Confirm 4.4.2 Note 3 cannot cos same situation, quickpic cannot do **** to microSD, hence i'm using back Samsung Gallery and it's loading stuff at snail speed lol
zXioNGz
Maybe in 4.4.2 the restriction still not applied on every apps bah hahaha. I still can delete movies via Mx player pro on tab pro 10.1
