lonerzboy
- Jun 20, 2009
I had some slight cracking sound but I played at maximum volume then I got it
Mine is only halfway to max. When people call me, also got this cracking sound.
My volume is halfway to max, and the music im playing are from both my phone and spotify.
Check if your dynamic normalizer is on or not. if on, turn it off.Hi! All. I plug in my Z3 to some speakers & noticed volume is very soft even at max. I was listening to the radio using the fm radio app
probably will end up with the result in post no. 1749
My friend dropped his phone. Screen cracked right away. Strange thing is that both casing and glass protector no damage but the phone side and screen cracked.
Anyone knows where to repair or replace the screen? Sony will probably quote 300+ for this.
Or anyone managed to convince Sony to change the screen for free before?
You never know, some games do eat more battery juices than others.
My total screen on time is about 4 - 5 hours on second day for moderate to heavy usage, left about less than 10%.
looks bad and i can see that the knock on the top left corner is nasty, will be hard to get convince for FOC repair.
even if he says it break on its own, the knock mark is too obvious.![]()
i am not bothered much about the battery usage as long it can last me for more than 6 hours at work i am fine with it.
i will normally charge it whenever my batt reached somewhere 20-35%
$300? That exp siaz. $200 more can get new set liao.
How ur friend drop.
That's a really hard drop. Ouch.
On what surface?
Anyone new Z3 have apps like q0010sg, pizzahutsg, grabtaxi and AVG preinstalled?
May i know which telecom installed these, cuz i bought mine from MS.
Thanks~!
Thanks~!
my set is from starhub, I also got pizza hut and qoo apps pre installed, on top of the usual starhub TV, music and account apps.Thanks for info!
Was wondering why a sealed set would have this apps![]()
Thanks~!
