Sony Xperia Z3 Tablet Compact
mqz512
Any white and black demo sets to play with?
Bought LTE black from V3 earlier. WiFi version got white only at the moment. Only white casing available as well.
Got tempered glass screen protector from Adix bro.
lorettatay
Sony staff told me LTE only have white. Is it true or smoke me.
Sent from GAGT Android App
DoraemonBoi
For micro Sim, it can be cut to Nano Sim. For those older Sim card which is bigger than Mico Sim then cannot cut to Nano Sim. =:p
Wa, like that need to change sim card liao. Mine is the normal sim cut to Micro Sim. So I guess it can't be cut to Nano Sim eh. :(
carlover76
I think maybe can, you might want to check with those mobile shops first and give them a few dollars to cut if they tell you your sim card can be cut.
Check first before getting the sim card changed at Telco with a higher price. =:p
yhw22
when u buy z3 tablet compact, ask them to cut for u free lah. tix is what i did when i got my z tablet too. :)
lorettatay
seem like the sony staff at bugis smoking me. there are black and white for lte. %%$^$^.
yhw22
Introducing the most powerful and lightest tablet in the world, the Xperia™ Z3 Tablet Compact! Oh, do you know that it's also waterproof? Now you don't have to worry about water splashes when you laze by the pool with the tablet. Available from today onwards!
fresh from Sony Singapore FB
yhw22
It since like for WiFi version only got white colour based on Sony website. :D
If so, then likely will get LTE black. As only LTE got black. :s13::s13:
lorettatay
nope the sony staff told me lte have white only. aiya dont trust them liao.
