LG G3
miyamew
who needs a spare battery nowadays :s13: portable power bank is so convenient
just get a G3 and u wont regret
excpro
Thanks everyone for your opinions!
Came across some comments in forum saying some auto reboot issue. Is it a common problem? 😯😯
tt32003
So LG changed the free gift now ?
From free battery plus dock plus screen protector
To
Free bluetooth headset and free casing
Guess it can be considered as an upgrade in terms of the freebies ?
tt32003
Thinking of getting the G3
Now waiting for the telcos to cut price.
They had a price cut during the last IT show
SO now waiting for the next IT show and see whether they will cut the price again or not.
multi
To
I got mine in Sept 14 M1 and the freebie are...BT headset, Premium Battery pack, Selfie stick and screen protector. So now, is it upgrade or downgrade?
tt32003
Let's wait and see what they give for SITEX next week.
If got both battery pack plus blue tooth headset plus 50 or 100 dollars off that will be good.
Casing or screen protector actually worth not much
multi
Yes agree...:)
RockaRolla
To
i just gotten G3 last week from singtel, got free battery+dock, screen protector, bluetooth headset and a monopod and additional $30 off for buying online
and i did a quick check at singtelshop, now the promotion is they swap out the battery+cradle for LG case
so its hard to say upgrade or downgrade, is whether you prefer the battery+cradle or the original LG case
Seehuatsee
Using g3 for 3months alrdy, battery life was quite good initially. Now it drains very fast and idk why.
Sent from GAGT Android App
multi
Have you upgraded to the latest firmware? I'm using Version 10M and the battery improve alot.
twosix
you got a very good deal.
