Any1 had heat issues with zhone router? Mine is inside the DB closet and I feel the top surface with my hand is hot!!
Is it normal for the router to be so hot? I on it for 24/7 non-stop bcoz of my ip cams.
i bought a cheapo usb fan. connect it to zhone. to cool it down. together with my router
Aka Cut up the closet to ventilate and install liquid/nitrogen cooling?!I guess most of the newer places are designed as such where the FTP is inside the DB closet. Mine is no exception.
I believe looking at the overall ventilation of the DB closet (if all your networking gears are centralised inside. I have mine designed as such.) instead of just Zhone ONT as it is more resilient to heat than some other gears (eg. ERL/ERPOE). If heat within the DB closet can be released, then the heat generated from individual gears would likely not be an issue.
I am not good with pen down of thoughts. The gist of it is like think of the DB closet as a big PC chassis where airflow matters.![]()
This type of post will attract Maylyn jie jie hahaAka Cut up the closet to ventilate and install liquid/nitrogen cooling?!![]()
Can't help it, our tropical weather is such. Putting a usb fan under it helps alot. I do this for both Zhone and N66U. On the N66U, the temp sensor shows ~5 deg C less. Less heat, better ventilation, longer life.Any1 had heat issues with zhone router? Mine is inside the DB closet and I feel the top surface with my hand is hot!!
Reportingwater cooled routers anyone? Lol
How about water-cooled switches.Reportingwater cooled routers anyone? Lol
Anyway, made some headroom with the 'noise' issue after stage 1 changes I have introduced. Now running for 3 days and the noise level is within acceptable range while no impact in temperature (no rise up spotted). Stage 2 pending delivery.![]()
Currently how long does it take from registration to activation? My ST contract is almost up, and I'd figured that I should consider jumping ship, since ST doesn't offer ISP mail with 1Gbps.
ps: Not trying to ask if VQ has email, and I might as well use existing own domain name for email from here on whether I recon to ST or sign up VQ.
Well your first question is a rather tough one to answer. typically it should be between a week to a month, however *if* you meet with capacity issues from Netlink trust side, it might drag to 2-3months or even more(thou unlikely, since VQ follows up with netlink trust rather often).
So in lieu of that, welcome to VQ in advance![]()
Not LN2 ah? U supposed to bring phase change + LN2 later and we will set some Speedtest records right??
