- Apr 8, 2011
It's clear cut what.Well its up to interpretation again.
More expensive = like = good
Cheaper = don't like = not good
Or am I missing something here?
If so, please educate me.
I dont think there's an active agenda against u, but u really need to relook at how u convey ur messages. Dont follow the current gahmen leaders, citing misunderstanding and stuff![]()
So bad, poke fun at our glorious smu undergrad supreme leader of singapore who stands over you.
Conventional wisdom tells you not to start a argument if you're not confident winning it.
I tried to be civil initially, whereas some people just tried to put me down for whatever reasons. To me, I am a highly competitive person, therefore I rarely back down from arguments unless I really screwed up somewhere. I treat people how they treat me, simple logic. However for those who cross the line, then I don't see the need to hold back any aggressive statements.
Sound matters more, listen gao gao first and don't go for the cheaper one later you don't like.
To be honest, relook and read it aloud
The first part seems fine, then u made a reference not to go for cheaper one lest he doesnt like. Maybe removing 'and' and rephrasing it to pricing doesnt necssarily reflect the performance/preference..
Idk man, my language sarks big time but i thought ur line made certain items absolute![]()
Ok for this part, you pointed out that my message could be unclear to others, I do agree with you on this part. Thats why I clarified it in my later post that a cheaper IEM does not necessarily warrant a purchase.
Usually people have the mentality to lean towards the cheaper item, I didn't imply that cheaper means lousier, or being expensive means better.
TBH, 8A and 8C isnt considered cheap since their RRP is at least $1.8k. Its just that the discounts make one model looks cheaper than the other. And both are supposedly sound similar with some minor differences, to those that had heard it.
I not sure about how they sound thats why I'm going down to test.
Lose to Fitear, thats for sure... Dun bother...
Well, nothing is definite. Although the probability is extremely low but I will still try.
When you going to try Kaiser 10 then?
Comparing 8a and 8c.
If you prefer a more gao and lush sounding mids the 8a is better. But after wizard left heir, i am not sure if the 8a still sounds the same.
If you prefer something less gao and more air in the music. Go for 8c.
Shall see whether i will like the new 8A or not... Treoo's set is from 2014 de, so it should be after Wizard left.
But both bass are good?
