Help
Nosferaty
Guys I just built my own pc and now is trying to set up. For some reason, I can't connect to the Internet. How do I do so? My motherboard is h81 hds
muddle
Install ethernet driver from cd.
Usually win 7 onwards can detect ethernet port automatically though.
tungsten2
Check Layer 1 - Physical Layer
- If you see your LAN port, there are 2 LEDs.
- If you see a stable Green LED light up, your physical connection is there.
Check Layer 2 - Link Layer
- If you see a blinking AMBER LED, that means there are data activity
Are you seeing the above LED lights ?
If no, most likely is cable faulty or lan port faulty.
If yes, what is the IP Address you are getting ?
