tae_oppa
- Jun 21, 2014
Its true I am the hill
how? how's your y1s1? what's your predicted cap? 4.8?
jus s/u loh. i guess most ppl will enter y1s2 with CAP> 4.5 lol.
bend chiu from chat room
sux moi kkj u think every1 can get at least 1 A?![]()
Maybe >4.5 is a bit of a stretch... but 4.5 >= isn't too much of a stretch, and I think it will be practically impossible to find someone with <4...
do u honestly think that way? why are u so insensitive![]()
Please read the context miss. This is regarding the first years' 5 SU policy. As long as they have 1 B+ and above and if they SU all others below (which is likely given they can only use it then), they will get >=4.0. More than a third and almost half the cohort for each module gets B+ and above. Each student takes 5 modules. Simple statistics. Why you don't read?
If my time had s/us, I would have probably entered the second sem with all S grades haha
Hahah. So the other half of the cohort are invisible and hence its impossible to find! *brilliant* why didn't I think about it earlier hahaha
actually is jus 3.125% of the cohort...
this is assuming a uniform distribution of grades which is a very unrealistic assumption... but then if u consider many other factors, like the better one will predominately occupy the A- to A+ range, leaving more room for the rest to atleast get 1 B+ and above out of the 5 modules they take... OR some students even tho they r weaker in general is likely to have atleast one module that they are good at... OR students are likely to take modules (GEK) that they are likely to score well... then maybe a low % estimate is not that unrealistic.
