SHARE your RESALES, BTO, Carpentry, Electrical Quotes for comparing
Strawhatpirate
Dear All,
I saw a few ppl posting their individual request to help review their quotes.
I just found out HWZ admin will remove any contractor trying to publicize their services.
So this thread will be solely and strictly for existing home owners commenting on quotes for new up-coming home owners.
Cheers
Strawhatpirate
Electrical Work Quote i got
Supply and install Light Point - $40
Supply and install 13Amp Power Point -$54
Supply and install 2 x 13Amp Power Point - $64
Supply and install 15Amp Power Point / Aircon Point -$107
Supply and install 20Amp Power Point / Heater Point - $122
Supply and install Telephone Point - $55
Supply and install SCV Point - $107
Supply and install Fan Point -$43
Supply and install Dimmer Point - $80
Supply and install 2-Way Point - $95
Supply and install New DB Box c/w ELCB and MCB - 16 ways (HDB only) - $360
Supply and install Output Cable to Hob / Hood / Heater -$82
Supply and install New Switch Socket -$62
Supply and install 20Amp Isolator -$155
Supply and install Network Point -$155
Supply and install Ventilation Fan Point - $69
Installation of Normal Light / Spotlight / Down light - $10
Installation of Pendant Light / Fan -$80
Shifting of 1 x 13Amp Point / 2 x 13Amp Point -$31
Shifting of Light Point / Switches -$31
Conceal of Light Point / Switches / Power Point -$60
For anything less than $200, add in $120 for transportation :s22:
marc2002
Kitchen cabinet (Postform)
Ard 1.88m.
6 blum hinges
3 blum tracks
$1k
Baywindow
2.91m x 0.6m x 0.53m
10 blum hinges
$1k
Parquet Floor
Approx 4.6m x 3m & 3.2m x 3.4m
Burmese with skirting
$2.2k
demongod
anybody know how much it will cost to parquet living room and rooms?
ipaq4444
$155 for per network point. lol
catwhisperer
Can I get some comments on this quote please?
to supply labour to lay wall tile on wall (living room) $ 12.00 psf (we are looking at around 300sqft) - reasonable? not craftstone/craftbrick.
LED light strips for undercabinet and abovecabinet lighting - is $15m per metre, $40 per LED driver reasonable?
Strawhatpirate
Hi Cat,
$12 psf inclusive of tile already? normally tile is $3 - $4 psf
so labour and material cost is $8, which is within the market rate.
For LED and driver, you went directly to the shop right?
You need different size driver for different length of LED, so i just wanna ask, $40 is for your total length? or you need multiples of it?
catwhisperer
Hi Cat,
Hello, thanks for replying.
The $12psf does not include material, and is for labour for craftbrick. Contractor says if it is normal tile e.g. 165 by 1000mm, his labour is about $8psf. ok right?
For the LED and driver, he will source - I dont really know if it is strip or tube, is one cheaper/more wuhua/better quality than another? It's for undercabinet and above cabinet lighting. For the driver, he is just charging me $40 for 1 pc of driver, the area is not huge so I suppose 1 would be enough.
Strawhatpirate
So are you doing craftbrick or general wall tiles :s22: ???
anyway, i got a contractor who do $6.50 for providing labour to lay ceramic/homogeneous wall tiles (600mm X 300mm)
if you want to source for another quote for labour for craftstone, pm me
the main difference i feel for strip or tube LED, is for strip you can bend along the corner in the cabinet.
Strip have individual spots that might spoil in the long run causing "breakage" in the light
depending on your usage, not say which one more wuhua. both also ex..hahaha
unless u change to fluorescent tube
for LED, if you need driver should be using strip already, becoz normally 1 driver support 2 metres, so how many to use depend on how many strips (under/above cabinet lighting you want)
im guessing your area is >2 metres if you think he is only using 1 :s13:
i got quoted 1 driver for $35 for > 2 metres.
