2.1 Speaker discussion thread II [consolidated]
evildoctor
This is the new thread for all 2.1 speaker discussions.
The old thread is here:
http://forums.hardwarezone.com.sg/h...s-discussion-thread-consolidated-3198091.html
(Mod Edit)
Hey Guys! I need help! I'm the type of person who like to listen to radio! So I'm wondering is there any solution where I can play radio from my swans speakers without plugging in through computer or any Itouch or iphone or mobile phones? Like low consuming products? Does anyone have any ideas? Thanks much! Appreciate the help!
produde1999
check your radio if it has any line out.
mypillowtalks
THe only thing i can think of is the cheap $28 nokia army phone.
icecapt
Sansa Clip+ ? cost around 50+ inc. ship to singapore
Solo_Apple
Can anyone recommend a 2.0/2.1 speaker set as an upgrade to AEGO-M 2.1? Thank you.
KoChi
anybody using focal bird 2.1? is it good? currently using focal xs2.1
origino3
seen alot of comments about swan m50w. Will it be a recommended speaker if it is mainly used for movies?
produde1999
2.1 speakers suits best for movies. So yup I recommend m50w for movies.but of coz if you have the money, buy a good 2.0 and add a real active subwoofer will perform way better.
yunie_
any active subwoofer you might recommend? budget around 500
Iron_Maiden
hey guys,
My klipsch speaker already spoilt. Should I send for repair or buy a new set???
Can anybody advice me?
Goodshot
i thought most ppl go for 5.1 speakers if u are use for movies , i own m50w but i feel it is use for music . Movie whiles u can have better chioce
produde1999
Id say the d1080 and m200mkii are more for music. M50w is bassy set so its good for movies. Imho 5.1 setup is just a gimmick unless u pay $2000 for it. Paying $500 for a 5.1 setup will mean each speaker has $100 audio quality compared to $250 in stereo setup.
The biggest problem about 5.1 is placement. In order to benefit surroud sound, the listener must be in the centre between the front and rear speakers.
origino3
5.1 will be too troublesome to put around my room, hence 2.1 would be better but unsure of which 2.1 is better for movies so asking around :)
