LG G3
xRenol
twosix
Even at 1.38A is much slower than Samsung 2A charger.
Sadly, as i have said both my cables and charger are proven to go up to 2A. Think you probably have to read what i've typed before jumping conclusion
The LG charger is rated 1.8A only. If you're not happy with the rate, then go back to samsung lor. G3 gets fully charged within 2 to 3 hrs when it is almost empty. dunno why some people are so anal.
gt_5454
Downloaded pc suite. Tried to upgrade but keep getting "cannot connect to upgrade server" try upgrade again
mr168
After updated to lollipop, the shortcut to swipe and take screenshot via memo+ is gone.
Anyone knows how to bring this shortcut back?
khalille24
WECHAT AND WHATSAPP FONTS
Just updated to Lollipop and noticed a few things:
- WHATSAPP AND WECHAT: Still can customize the font but the contact/group name became a default font.
Hopefully it can be customized again real soon after the developer releases an update.
Gribber
Are you referring to yourself? Anal that is.
Look, i am just sharing my experience. You came in shooting someone down without reading properly and there you are saying people is anal due to that?
Some people here simply couldnt admit to their mistakes.
ryonee
So to update or not to lollipop? Like most here having slight problems uh... Lag and certain functions gone...
Sent from GAGT Android App
ah_cleo
Updated and i feel battery life quite bad. Haven factory reset though. Will try ltr and see out
tingtb
After did a factory reset, battery life improved alot.
erica_483
How's the memory leak bug? Fixed? Having 2nd thoughts abt Lollipop: I will miss my Xposed tweaks T.T
