vespaguy
- Jul 23, 2012
If you're cutting fruit, you could really consider getting either the KAI I mentioned (it's the same steel that Global uses - I just checked) or a Tojiro (you can get it from Razor edge shop). if you want something nicer, then you may end up paying for the design over the steel (likely and nothing wrong with that). Global's pricing is due to the uniqueness of the dimpled handles that are integral to the blade.
Either way, you win
Either way, you win
