Where to buy Cat5e/Cat6 Ethernet Cables at Sim Lim/Funan?
lctham
Anyone here has excess cat5e or cat 6 cable to let go?
I am looking at a 75ft (23m) plus-minus cable.
Please pm or text me 98598833.
Gum sia mak mak. :)
Epalite
Any body selling balance of cat 6 and punch down tool for keystone? Looking at DIY.
PM please! Thanks!
Update: got my Cat 6 and Keystone from SLT.
Epalite
I got my Cat 6 from 1 shop in SLS.
Later I found that you can get Cat 6 loose length from a shop in SL Tower basement. They also sell Cat 6 Keystone, punch down tool, faceplate and patch panels. PM me if you need the shop names.
Mogan23
Anarky
The giga speed thing is a gimmick and flat cables aren't recommended because the wires aren't twistd around each other to cancel crosstalk. Maybe someone can clarify on this.:s11:
Ah i see.. I was kinda looking at the flat cable cuz i don't know if the normal one will fit in the gap above my door.
ralliart_ray
Gum sia mak mak. :)
I bought 1 x big roll of Cat5E to lay my flat with LAN ports during renovation. I have excess, anyone needs any length can PM me with requirement and length. Got tools to crimp and custom accordingly.
Location is YCK.
nexusRAGER
so i should go SLT to get my Cat6 cable ? cause i only need 10m .. looking for quality ones
Mogan23
DIY and drill a hole in a wall or for a better looking option put it through existing wire trunking?
Yes :vijayadmin:
Can get other things for your computer while you're there :)
crystalnox
Anyone has those fluke cable qualifiers?
I've got a lot of old cat 5e and unbranded 'cat 6 flat' cables that I'm not sure if they're up to the task of supporting GbE. Need to sort out the inferior ones.
FljpFl0p
So where in SLT can I get an actualy Cat 5E/6 cable?
I went and got a "Cat 5E" at SLS at $14 for 20m and all I get is 90 Mbps.
I couldn't careless whether it's Cat 5E or Cat 6 since they both should be able to go to 1 Gbps, but it's kinda hard to identify a cable with genuine quality.
renfred89
cable quality is one thing. the crimping of cable is also another thing.
usually if they crimp wrongly, the speed will drop. If the cat5e is not tested to support 1gbps, then its kinda like a "Water goods".
i suggest you go by brands. Belden/3M are 2 reputable brands you can try..
FljpFl0p
Which store would you recommend to get those brands and what's the estimate cost for a 15m one?
htngwilliam
If u guys need short one, I can spare some also. I also crimp myself but rather tiring. Haha!
