I have bought a unit of 68U the week before and I have had it exchanged 3 times within 7 days.
While I have read and follow on this track but as there is no other router of my choice, I didn't to get one and have it tested today.
So far, yes it is hot but still within my tolerable range as I only switch it on for only few hours. I have no problem of setting up and have been using 5G with my MB Air.
I have also tried streaming on my TV through cable. So far have not encounter any problem.
Speednet test for 5G can get up to 500Mbps. I am ok with the reading but not sure if this is good.
Speednet test on cable can get between 800 to 900+Mbps.
My home network is simple and direct. Enabled all normal security protections. I hope I will not encounter any problem.
I have not upgrade my firmware worry of stability. My last 68U start to have problem after I upgraded the firmware.
