Lenovo A916 - $200 5.5' Dual 4G SIM
mar5000
"YES it has two sim slots , but at a time only one works. . if you need to use your another sim (which is only 2g supported , btw) you have to select it in the sim management and it will restart the phone for you 2nd sim and guess wht, now your 1st sim is useless." Quoted from qoo10 customer review. I think lenovo k3 is a better option if you don't need a bigger screen, also less than $200.
V
victorlht88
Guest
Seems like dual active, don't bother.
Sent from Samsung SM-T705 using GAGT
galliano
Its not dual active, dual active means both are active at the same time (data, calls can use at the same time)
Its dual sim, single standby (as replied from qoo10 seller), so its not real dual sim, probably a dual sim card holder inside (on a single sim phone)
Is this HP is duel sim or Single sim?
[Re] Sim Card
Dual sim,single stand by
I was assuming it works similiar to the Redmi devices. 1 slot is 3G and the other is 2G. Data only on 1 slot which normally would be the 3G slot. Thus the need to swap card slots when using local sim overseas.
aikhung
[Re] Sim Card
Lenovo just release new ROM last month Dec'14 to support dual standby. Below is the link to the download the ROM which only support Eng/CN.
(blog.cellphonemic.com/?p=624) can't post URL link
Below is the step to active the dual standby after upgrade to the latest ROM.
Activation Steps:
1: Input *#*#5448264#*#* on the dialpad
2: A916 will automatically restart then
3: Setting~SIM management~Standby Mode~Dual Standby~Activate
4: Dual SIM card dual standby available
galliano
Activation Steps:
Steady ...
Guy84
Sorry to :s12: this thread!
I am also want to know if this phone is good.. now the PC Show 2015 is selling @ $159.
Still considering on this..
Anyone can help? :s11::s11:
104305
if the dual sim activate/unlocked then will be good.
tclong
i just bought this Lenovo A916 :D
tclong
Update URL
Activation Steps:
Lenovo A916 Smartphone Latest Firmware Released 20150205
http://ask.lenovomobile.com/?q-602276.html
:D
