iPhone 6/6+ Screen Protectors
mikeeeey
Bough mocolo full tg. Tried to apply. However at all side that's near the white broder, it appear to have a whole stretch of air bubble. How do i remove it? Kindly advise. Thanks
Using mocolo on ip6+. No such problem. So far been working well for me. Best bang for bucks
discoburg
I think your iPhone and mine same batch. Ours cannot use tempered glass SP, no matter full coverage or not.
mocolo full coverage with thin borders? u need to keep "massaging" the side with microbubbles. i had minor small stretch of microbubbles and i spent quite some time after applying to try push the bubbles out. now, weeks on, cant even see the bubbles at all. luck, i guess.
chester121
Anyone using the GlassPro+ series from Fine element? Any reason why choosing the Mocolo is better i.e the thin coloured borders compared to the fully coloured glass of Glasspro+?
I know that Mocolo is better in terms of brand but just wanna see comparisons based on design and usage.
Thanks!
EJB
Thanks!
I bought the glass pro+ from HK, applied on my sis 6+ and today tested it on my friend's 6+. Not much difference.
I just like Mocolo for the smooth feeling on the surface when sliding my fingers across. I have tried $8.90 one from Cityhall Exchange the IT shop, and Mocolo (non full screen) and also the Mocolo full screen.
So far Mocolo re-application is easy, and doesn't crack like the $8.90 brandless version and I like the smooth touch.
chester121
So the biggest difference is design-wise i.e thin color borders or the entire glass is coloured black/white except for the screen right? I thought that the Glass pro+ looked nicer cos the whole tg sp is the same color and looks like the front iPhone faceplate. But I may get mocolo instead as it does boast better quality.
ah_kiat
I got the glass pro+ too. Yeah, same thinking, the glass pro+ looked nicer.
So far no regrets on buying glass pro+ as it really looked like without screen protector. The only thing is not as fingerprint resistant. But for a $7 screen protector, got nothing to complain about.
Cyberboy128
Currently using Mocolo for iPhone 6 and Note 4. Being trying different brands of Glass Protectors (mainly branded ones from retail shops) for both devices, I must say that I found Mocolo one of the best! Despite its low price, its quality is top notch.
For the "air bubble" / "helo effect", I think it is due the curve in the respective device. I understand that different device have different curve due to batch and output from different factories.
i.e. same glass SP might be ok for some but with bubbles for others. This also applies to non full frame glass SP.
lunatic_tokyo
Hi guys,
Need Intro for glass protector. Currently using rearth ringke fusion clear cover love it. Need a glass protector that covers the entire border if possible.
On a side note, any recommended glass SP to buy from Taiwan ?
chester121
Oh yeah, another major difference is Mocolo has oleophobic coating/some kind of fingerprint resistance to it compared to Glasspro+ right?
fade_white
Those looking for the elusive bubble free, full coverage screen protector, why not try wet films like BSE? the coverage is quite good..
paotan81
Hi all...I would like to ask you if IMOS ex 3D curving glass is compatible with apple silicon cover...and if you have some pics of both imos and apple silicon case with the iphone
ah_kiat
Based on specs, Glasspro+ supposed to have too. But whether is effective or not....
chester121
Yeah true, but imo after using any tg sp for a period of time, the coating wears off with use also. So even those with guaranteed oleophobic coating also will become ineffective over time.
IloveEmma
Btw guys, i brought Mocolo after Jimmy's glass broke twice in a few days. Maybe not good for a rough guy like me. Nothing against his glass but i think just usage pattern.
Mocolo is looking very value for money at $8 so far.
sigurros
Yah. Been using mocolo for the past month. No issue. For $8, is a no-brainer. Just did my 2nd purchase for standby.
And the glass is smooooth. However, only the oleophobic is ok only.
gapboy
i use cheaper tempered glass brand nowadays , no point on expensive one as it is prone to wear and tear too
mikeeeey
I used expensive tempered glass chipped within 2 weeks. Cheap one still going strong after 3 weeks. So far so good.
