If u r a real audiophile, u will know that external dac/amp is much better than soundcard in all ways....
what about liquid cooling vs fan ? will the dust vary ?
Still the same.
Liquid cooling
Transfer heat from processor using liquid to radiator. The radiator fan will dissipate the heat. The radiator and fan will accumulate dust.
Aircooling
Transfer heat from processor via heatsink and heatsink fan will dissipate the heat.
Heatsink and fan will accumulate dust.
It makes absolutely no sense to spend 4k on mitx setup since the upgrades on it is pretty limited
It's better to spend 2k now and save up the rest, 2-3 years later spend another 2k for the next gen pc
can reco me a motherboard with good sound card ? and seems like i need to change casing too le![]()
Everything same except motherboard and casing.
MSI H97M-G43
Bitfenix Prodigy M
Wait for some random IT show sales with creative inside. Their sound card discount price is very good.
) but what do you use for gaming? Consider a Creative Gigaworks instead.The difference is minimal with and without soundcard. The speaker is usually the one making most of the difference.
Most likely your shitty music is due to shitty speakers.
You use Senheisser headphone for music (BTW using Senheisser makes me doubt if you are an audiophile) but what do you use for gaming? Consider a Creative Gigaworks instead.
i5-4460 + Msi h97m g43 ~ $406
G.skill 8gb ddr3 x 2 ~ $200
Crucial mx100 512gb ssd ~ $315
Wd blue 1tb ~ $75
Msi gtx970 armor edition ~ $499
Superflower leadex 650w ~ $139
Corsair 240 Air ~ $139
Win7 64 oem ~ $130
$1903 , sound card see which u preferred.
i dont think ill be getting the gtx 980, as what i've read gtx 970 is good enough for all ultra ? will the gtx 970 last for the next 2-3 years for high end games ?
oh i forgot im an audiophile, want a good sound card for music and games![]()
GTX970 @ $500 is the best price to performance ratio graphic card. The next better one is GTX980. GTX980 is only 20% better than GTX970 but cost $850
lol. i didnt say my music was shitty due to my shitty speakers, i want a sound card because my current motherboard with on-board sound card is shitty, only got quad dont even have 5.1, i use sennheiser for gaming also and why is using senheiser makes me doubt im an audiophile ? now audiophile got play what level to own ? lol so i use sennheiser means i can't be an audiophile ?
Dont listen to those who say Sennheiser sucks. The HD 800 is going at 1.5K SGD and is yet its still highly popular to audiophiles around the world.
I personally listened to HD 650 and are geniunely impressed by the quality of the sound they produced from my Iphone alone. (Together with an portable amp)
Obviously u seem to forget the existence of AMD card. If you want to follow strictly to price performance ratio, 290X score even better than GTX 970 locally in that aspect.
You cant judge someone who are or are not audiophiles when they go for a certain brand just saying.
And trust me, onboard sound and dedicated sound card DO MAKE A DIFFERENCE. Coming from onboard I straightaway notice the big jump when I switch to ASUS Xonar DX. Again that is only noticeable if ur speaker is good. If not the difference would be marginal since ur speaker cannot bring out the potential of the sound card.
hi all,
please recommand me the most valued gaming diy pc, budget 4k !!
play high-end games, hopefully can get a system that works as well as ps4 without lag
is there any difference with liquid cooling and normal fan ?
thinking of getting those cool cool chassis too !
is it worth to get 120hz ? or stick to 60hz
I preferred to play games on console cos i rather spend 500-600 on ps4 than thousands on PC.
Indeed, one of the advantage of using consoles is you do not have to worry about updates, installing games to the hard drive and furthermore,
maintaining a PC can be more expensive than maintaining One Xbox or PS4
