thiamhui
- Jan 3, 2001
Yes, iPhone 6 Plus with iOS 8.1.3.Any IOS Devices?
Assume you are not on the Unlimited Plan, under Advance Settings -> LAN -> IPTV, select "Manual" for "Select ISP Profile". For Internet, input "10" for VID and "0" for PRIO.Hi guys, I recently purchased this router and I can't seem to get it connected to the Internet. I followed the instructions in the manual but the WAN LED is always red. As I am currently using Singtel fibre plan, I called up Singtel but they said they cannot help as they do not have support for 3rd party routers. So I was wondering if anyone knows whats wrong with it or is there any way that I can solve this problem? Much thanks in advance.
Thanks I switch over liao ............3rd post down is a link and first post has info, CLICK THIS
I did finally get an IOS wifi hang with dd-WRT but I also think I found a solution for it in that thread. Testing now the solution .
The only thing I do not know and have read conflicting stories on is what is the mW of the 2.5 and 5GHz on asus firmware so I can match with dd-wrt for signal strength.
But in all honesty dd-wrt has its problems too, those as of yet affected me.
No longer feeling like I wasted my money
There's a preset profile already. Select "SingTel-Others". MioTV to port 4.Thank you for your help. Got my internet working for the Port 1 and 2 on the router. However, Port 3 and 4 isn't connecting to the internet. Do you know how to solve this problem also? I am currently trying to connect my MioTV to the Port 3
One issue ......... how come the 2.4Ghz LED not lighted anymore.........
Ok noted.The 2.4 GHz light and sub light do not work with dad-wrt a known issue with dd-wrt , you get used to it tho
Try going back to "Manual" for "Select ISP Profile".WOOHOO!! Finally got my MioTV to workThank you thiamhui!! Thank you so much!!
Edit: OOps!! Is there any way I can connect 2 MioTV set-up boxes to the router? Or am I only limited to one. The one that is connected to Port 4 is working, but not the one in Port 3.![]()
For :-
Internet - VID = 10 PRIO = 0
LAN port 4 - VID = 20 PRIO = 4
LAN port 3 - VID = 20 PRIO = 4
Ok noted.
By the way the interface not as user friendly than Asus Bios...
in ur wireless log, does the "connected time" of ur devices keep resetting or stay connected for 10 over hours? In addition, do you have any iPhone 6/6+ connected via 5GHz?
For my case, my devices (AC devices) keep disconnecting and reconnecting when they are put to sleep. No dropping when the devices aren't in sleep mode tho. This is kinda irritating, as my phones will miss whatsapp, fb messenger notifications when they are in sleep mode.
Bingo .......... I am in the same situation with you now..........
some of my devices (AC or N) does keep disconnecting and reconnecting when they are put to sleep. No dropping when the devices aren't in sleep mode which all along I never have issue when using them .....
IPAD is one that will stay connected in sleep mode thought....
This is exactly the same issue with my iPhone 6.
Try downgrade the firmware to 2769. It works better…Got to use back 2.4G....
