The Nexus 6, the Lexus of the Precious Nexus?
kennyg1969
You must consider the risk that proximity sensor will not work properly. I just bought one temper glass at tampines mall last night,later on once I make a call, the phone is off and can not wake till call end. I wonder anybody can refer a verified brand for me.
Sent from Motorola NEXUS 6 using GAGT
As long as your tempered glass is covering the proximity sensor, your N6 will mess up with calls.
Get a tempered glass that does not cover the sensor which located to the left of the speaker grille.
Nillkin has the perfect glass that is not blocking the sensor
gerald91
anyone facing problem using cm12?
my nexus 6 just did a auto reboot and it got stuck at boot animation then i power off and on again but right now is OK...
is this normal? or what should i do ah?
tatsit
High Honorary Member
can buy from sg?
garychengjw
am using cm12. no problem eh.
walkofwinners
did you install any rogue apps prior to this?
ybeex92
oh wow i live in tamp and didnt know they sell it there.
how much are they selling and which shop?
I've been doing research and found that OZRLY is good, according to other n6 users.
unfortunately it doesnt ship directly to sg, have to use forwarder.
shawniiex
Honestly still normal for a rooted phone.
Especially since the software isn't 100% perfect yet. Anything can happen.
GeSteSoh
Cm12 vs pure shamu, which one nicer and more stable?
Tried both and they were stable, I felt pure shamu was faster in its UI maybe cos it was not forced encrypted like CM12.
I also prefer the Pure Shamu settings over cm12 thats gives you things like DT2W/S, nav bar editing etc... oh also gives the abilty to pin unlock without needing to tap the check sign (like in ios)
CM12 gives you themes but needs to be paid, pure shamu gives Material Dark which is free and most I really thought necessary...
However pure shamu doesnt do OTA updates so hopefully that changes soon.
GeSteSoh
Chroma looks good...
attachment.php
attachment.php
porcu
Which is the good theme for CM12? I think having more black is good as it can help save power.
