The Nexus 6, the Lexus of the Precious Nexus?
porcu
I want also. Send me PM!
But I will be visiting Japan beginning of March tho.
jingwei
Can bros share what brand of screen protector have you all used for our reference? Read and saw that the phone had the same curved edge like the iPhone and Note 4.
porcu
Using Nilkin. Not too bad but no full screen cover.
GeSteSoh
Just saw this post.. is it to late? I wan 1 black
Looked at the translated version it says: Delivery information: This product will be reservation commodity will be released the end of February.
Will keep lookout :vijayadmin::vijayadmin:
my chroma ok leh, no issues. 8-10% overnight. but i realised it burns more battery on WiFi than on cellular.
Mine shows the wifi always on even when I'm not on wifi.
Installed lean kernel to block some of the wake locks. Need monitoring further if doesn't improve I'm flashing other rom.
Any other recommendation? Anything except cm12 pls.
GeSteSoh
Nexus 6 vs iPhone 6+ photos...
Took some shots using the two phone cameras in auto HDR. ;)
Only resized to fit the page. Unfortunately photobucket compresses... :s22:
porcu
Arigatou. I tot not working as it doesn't show up on storage. Apparently I need to use a third party app like ES Explorer to see.
Unless you root and install stick mount, you cannot write on exFat or NTFS.
Only can do so on the old and clunky Fat32 :(
kEvinErd
I searched for you using GOOGLE.
Wow thanks. Didn't know Nexus 6 supports read/write OTG without root using ES Explorer. Write access is only for FAT32 format though but I'm all good since I don't have large files.
Now I can make use of my Meenova more frequently. Too lazy to root my Nexus 6.
