The Nexus 6, the Lexus of the Precious Nexus?
Andrewtst
:mad:guess we all agree the N6 battery SUCKED!! :mad:
Well, apart from that, the phone is really good. :D
The colour is another problem but maybe can be fixed via software.
* tried Kcal but crashed on my N6 (Cyanogenmod12) - bummer *
Comparing to my S5 Prime (also qHD) , the color is over-saturated as I preferred to always
set my AMOLED devices to RGB or Cinema mode.
Why won't Cyanogenmod or other people release some emulator to the Samsung colour calibration settings? That would be really cool.
Beside slightly warm, the Nexus 6 color saturation is exactly same as Note 4 in adapted default setting.
Now my screen no more warmer after slight tune using CM12 bundle color tune.
kampong boi
try rebooting your phone?
It could be a hardware issue (worse case) but you can try to reset & restore the phone if anything else fails.
If it is a hardware issue, need to send for repair. But I am not sure where... maybe can try irepair.com?
Maybe it is a good time of you to unlock, root and flash to a custom rom. :)
I have restarted my phone a few times, but it doesn't solve the problem, might call the Nexus hotline since I am in Au or sent it to their office.
Heard Telstra or Optus might bring in N6 :o
porcu
gave up on Kcal as it didn't work for me. :(
Installed Screen Balance. Great app and it worked.
Now, I managed to calibrate my screen to be similar to that of my S5 Prime qHD RGB mode.
Plastick
personally like vanilla android a lot since the nexus 4 time, also why i have bought nexus 7 gen 1. but very sad, till now this nexus mobile series battery life still very disappointing which is the reason why i have not make the switch for mobile phone.
shawniiex
Funny how the Nexus can have a legacy of disappointing battery and camera performance, but when they try to make it better doesn't turn out much better still.
gerald91
help help help
Hello All,
i need help badly. i can`t use my nexus 6 now (bricked)
last night my nexus 6 went into auto reboot and it got stuck at the boot animation, so i tried to turn it off it but i can`t so i went into recovery mode and restore to my stock rom but half way installing it, i dont know why it failed and now when i turn on my nexus 6, its stuck at the teamwin page (i can`t even get in to recovery mode)
tried using wugfresh tool kit to unroot but failed
before this happen
my nexus 6 was running custom rom CM12
ahhh, can anyone help me with this problem:s11::s11:
Thank you
Hello All,
before this happen
Thank you
What is the last msg on the wug log?
shawniiex
Hello All,
before this happen
Thank you
Well..
You should still have the cm12 rom file and the gapps on your phone somewhere right?
Just reflash again lo.
